Hey guys this is my first build and I would like an opinion for it Im going to use it for gaming and my budget is around 450 US dolllars or 520 euros(I live in Romania)
cpu-AMD Athlon X4 860k black edition
Motherboard-Gigabyte GA-F2A88XM
GPU-Sapphire Radeon R7 260x(2GB GDDR5)
Hard Disk-WD Blue SATA III 7200 RPM-64MB
RAM-ADATA XPG V1.0 8GB DDR3 1600MHz Dual channel
PSU-Sirtec High power element(80+ bronze)
Im going to choose my case later
https://linustechtips.com/topic/374772-my-first-pc-build/
 Will a corsair cx430M 430W do the job? and I think having 4 cores of the X4 over the two of the G3258 is better(sorry if im wrong)
For the CPU watch this video.
But you need to OC the G3258 to have these performance, if you don't want to OC the Athlon could be a good option.
And yes with a Corsair CX430M you should be alright.
https://linustechtips.com/topic/374772-my-first-pc-build/#findComment-5069136
Dont get the pentium. Its a 2core cpu... and GTA V sutters like crazy on it, something you wont see on fps meters.
The athlon has 4 actual cores. And even for single threaded games it will perform the same as an overclocked pentium if you game on anything higher than 1080p. Or 97% as good if @ 1080p.
People who say there are differences get their information from 800x600 resolution CPU benchmarks where the overclocked intel gets 500fps and the athlon can only manage 400fps for a single threaded synthetic 3d benchmark.
https://linustechtips.com/topic/374772-my-first-pc-build/#findComment-5069298
