I've recently decided to build a PC and was wondering, firstly, what fps and settings I can expect in the newer games at 1080p I will get and secondly, if anyone has any improvements at a similar price?
CPU- AMD FX-6300
CPU Cooler- Cooler Master Hyper TX3 Evo 43.1
Motherboard- M5A78L-M Micro ATX AM3+
RAM- Corsair Vengeance Pro 8GB (2x4GB) 2400 memory
Video Card- XFX Radeon R9 280X 3GB Black Edition
PSU- EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Any help would be greatly appreciated :)
https://linustechtips.com/topic/374767-my-first-build/
Get an amd 8350 if your wanting amd, but otherwise I'd go for an i5. I had an fx 6300 and it was kinda slow in more modern games, unlike this i7
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/374767-my-first-build/#findComment-5069064
CPU- AMD FX-6300
Are you overclocking?  If you aren't, I would pick up a budget xeon.  If you are, pick up a core i5.
https://linustechtips.com/topic/374767-my-first-build/#findComment-5069077
I was thinking about getting the 8350, but where I live, the UK, the i5 would cost quite a bit more for a K model, which I believe I would need if I ever wanted to overclock?
If you want an XFX card, I would pay the extra 10 or 20 USD to go up to the R9 290.  Then, you get an extra GB of GDDR5, more stream processors, and a (slightly) better memory bus
I live in the UK which I probably should have stated although is the difference when jumping up to R9 290 going to be substantial in gaming as I would be willing to do that if it's worth the extra money.
I would probably want to overclock in the future so an i5 would be ideal but the pricing may be an issue right now, although if an i5 is a huge improvement I'd probably be willing to wait till I have the money saved up to get the i5.
https://linustechtips.com/topic/374767-my-first-build/#findComment-5069109
Two other things: you seem to be overkilling the ram (but nice find, that's some good RAM).  Also, I think you will only need a 500 watt psu (I know EVGA makes versions of that current PSU in 550 Watt).
The only reason the ram is pretty good, is because it's a pretty great deal (around 5% cheaper than the cheapest 1600 memory). Thank you for the recommendation on the PSU though, I was pretty unsure of how much power I would need so I thought if I go a bit higher I'd be safe, but anywhere I can save money without losing performance is very helpful.
https://linustechtips.com/topic/374767-my-first-build/#findComment-5069121
It depends on your resolution of gaming.  If you are at 1080p right now, then the R9 285 will be just fine.  But, if you want to upgrade to a higher resolution later, the R9 290 will definitely be worth the marginal price increase.
Over the FX 6300, the i5 is a HUGE jump up.  If you want to OC, I HIGHLY recommend saving your pennies.
https://linustechtips.com/topic/374767-my-first-build/#findComment-5069140
I will probably be at 1080p for a while so I guess I could just upgrade when I need to in the future. I think I will wait for an i5 though.
https://linustechtips.com/topic/374767-my-first-build/#findComment-5069218
