i have this line of code:
 # save computer name in variable 'computerName' for readability..    $computerName = $env:computername;     # print information    Get-WmiObject -ComputerName $computerName Win32_NetworkAdapterConfiguration | Where-Object { $_.IPAddress -ne $null } | Out-GridView -Title "Network information";
which opens a window and displaying info of the network adapters but how do i exclude some of the stuff like if i ONLY want to see IP-address and Gateway in the window there? is there a command to only make it include some of the categories?
Edited by alpenwasser
code tags
AMD Ryzen 9950X3D [x2 360 Rad EKWB] | Asus Extreme x670E | RTX STRIX 5090 OC@3GHz [Alpha Block] | Corsair HX1500i | G.Skill Neo CL30 6000MHz (2x32GB) | Samsung 9100PRO 8TB Gen5 + MP700 2TB Gen5 + 980/950 Pro 1TB M.2 | x6 85PRO 512GB | NAS@10Gbit/s 4x 24TB Seagate Exo Raid 10 (2x 1TB raid 1 NVME Cache) - 4x 1TB NVMe Raid 0 + Backblaze | Lian-Li o11D XL | Main Screen: Samsung OLED G9 | AUX: LG IPS7 27" (x2) LG CX 55" G-Sync | 10Gbit/s ISP connection | Copyright©1996-2026 Teletha All rights reserved. ®
https://linustechtips.com/topic/374742-powershell-help-fast/
    # print information
ipconfig /all.  All you need.
https://linustechtips.com/topic/374742-powershell-help-fast/#findComment-5068679
no i need to learn how to do this
https://linustechtips.com/topic/374742-powershell-help-fast/#findComment-5068686
Oh fail. My bad. I was thinking of something else. What code are you using?
https://linustechtips.com/topic/374742-powershell-help-fast/#findComment-5068695
 the one above
https://linustechtips.com/topic/374742-powershell-help-fast/#findComment-5068703
 the one above
Fail, I was meant to say, language. :P
https://linustechtips.com/topic/374742-powershell-help-fast/#findComment-5068734
oh well in powershell ISE im not so good with programming .. have no idea what language it is if not powershell is enough =/
https://linustechtips.com/topic/374742-powershell-help-fast/#findComment-5068746
use the select-object command.
 # save computer name in variable 'computerName' for readability..    $computerName = $env:computername;    # print information    Get-WmiObject -ComputerName $computerName Win32_NetworkAdapterConfiguration | Where-Object { $_.IPAddress -ne $null } | Select-Object -Property IPAddress,DefaultIPGateway | Out-GridView -Title "Network information";
Keep in mind that Powershell will not display all properties, use get-member to see all then use select the one you are after with select-object.
https://linustechtips.com/topic/374742-powershell-help-fast/#findComment-5073385
