right speaker does not work after driver update
Solved by zanthros,
Check for a bad wire on the speaker cable or since your board has the Realtek ALC892 8 channel chip in it just use the full realtek driver and re-task a different audio port for your speakers if you are just using 2 speakers.
Featured Topics
8
AcidVinyl ·
Posted in Graphics Cards3 -
Phantasmagoria ·
Posted in Cooling2 -
BotherRed ·
Posted in General Discussion4 -
2
