Freezing while NOT under load.
Solved by yoghurt13,
Update after months, a solution: I recently saw that somehow the CPU was frequently undervolted to 0.982V while wanting to operate at full speed, also the assigned voltage was like 1.225V, and raising it to 1,4V was a pain because you can only ADD voltage to the current voltage with this mobo, if you assign it to +0,05V it will only add it after you save it and reboot, now you have to set that again if you want to add another 0,05V. Now running at a stable 3,8Ghz without any freezing.
