As the title says, I'm using the iGPU built in on my 4670k until my old PC is sold, so I can get my 770, so I wondered if I got my 4670k locked into a stable OC before I got my GPU if the iGPU will also perform better? Or should I just wait to get my GPU and OC my CPU then?
Case: NZXT H440 | CPU: i5 4670K @ 4.5 GHz | GPU: MSI 970, Kraken G10 | Mobo: ASRock Z97 Extreme3 | Cooler: H100i | PSU: Corsair AX750 w/ Sleeved Cables | Display: 3xBenQ RL2455M | Fans: 5xNoctua NF-F12, 1xBitFenix Spectre |
i dont believe ocing your cpu ocs your igpu...i think that happens seperately.....i think saw something in msi command center or whatever to overclock the igpu but i would just leave it at stock. I was easily able to play games on low at 720 such as far cry 3 blood dragon and grid and what not. Obviously its a igpu so it wont give you awesome performance but yeah....leave it at stock imo.....
-Anubikai
| i5-4670k at stock until I do a custom WC loop | H80i | Asus Matrix Platinum 7970 at stock until I do a custom WC loop  | MSI Z87 GD65 | 1TB CAVIAR BLACK | 250gb Blue Scorpio | HX750 80 PLUS GOLD modular | 16GB INTEL EXTREME EDITION PATRIOT 1866MHZ | Coolermaster Storm Enforcer with two Red 20cm fans intake and exhaust |
Hello there! There are separate options to overclock the iGPU in the Intel CPUs. Look in your motherboard's BIOS options under overclocking, there should be a setting for internal GPU clock speeds.
-fishymamba LTT Intel Response Team
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
