Hello to all boys, here I am back with a new project, very different from my standard made-scale "reduced"
as the PSPC (computer inside a PS1) and the newcomer, the cub8 (mini-ITX case that I upset the inside to mount a 240mm AIO).
I also take this opportunity to say that the project will take inspiration from my current PC, to which I gave a touch of elegance that was missing, Kathrine.
TfT, the name of the new project, to which the name refers to the two "towers" on the sides of the case.
Here are some render illustrating what I want to do.
Sponsor:
Coming Soon..
Config:
Case: Cooler Master Trooper
Fan: 15x Cooler Master Silencio 120
PSU: Cooler Master v850
CPU: i7 3770K
Motherboard: MSI Z77A-GD55
Ram: 16GB
VGA: (?)
SSD: 2x Transcend SSD370S 128GB
Cable: ModdingStylez Silver/Grey/Black / Coolforce by Nanoxia
Liquid cooling:
WB CPU: XSPC RayStorm
WB VGA: EK thermosphere
Pump / Reseivor: XPSC 750
Tubes: Coolforce by Nanoxia
Fittings: Coolforce by Nanoxia
Liquid: Coolforce by Nanoxia
Radiators: 2x 360 60mm
The changes that I will do, as you can very well be noted:
-double Radiator 360 push / pull
-Motherboard Rotated 90 ° with I/O on top
-MidPlate Ad-hoc
-Colours Main Black / Silver
-Sleeve Of all cables
-Front And back in mesh
Thanks for the attention :)
Facebook Page / Instagram Page / Modding ART Page
Projects:
PSPC (2013) > Kathrine (2014) > Cub8 (2015) >TwinForceTower (2015) > Vector (2016) > Etna Comics 7 #EC7 (2017) > Etna Comics 8 #EC8 (2018) > Yin Yang (2018 in progress)
https://linustechtips.com/topic/374273-project-twinforcetower/
DAMN! nice idea hyped for this
The Y.E.T.I. is in progress?Whaaat? (modding aproach&build log)->http://linustechtips.com/main/topic/355618-project-yeti-first-build/
[READ THE COC BEFORE POSTING][Check twice cut once][NZXT rules:D][Dremel is Love Dremel is Life][COOKIES ARE GREAT][LOGIC]
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5062871
It will be a great adventure, I never wanted to make the projects "in large scale", it will be fun  :D
Projects:
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5063077
I also take this opportunity to say that the project will take inspiration from my current PC, to which I gave a touch of elegance that was missing, Kathrine.rMr9zsT.png
Sponsor: Coming Soon ..
Config:
Case: Cooler Master Stryker (?)
Fan: Cooler Master Excalibur 12x / 12x Cooler Master Jetflo (?)
PSU: Cooler Master V850 (?)
CPU: i7 3770K
Ram: Avexir Raiden (?)
VGA: HD7950 / R9 290
Cable: Silver / Grey / Black (?)
Liquid cooling:
Tubes: ??? (Rigid)
Fittings: ???
Liquid: ???
Radiators: ???
-MidPlate Ad-hoc
-Front And back in meshk
how does everyone on this forum make these cool banners
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5063171
connections...:D look at mine :) wich @C0LL0SS0S did
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5063547
Photoshop for the Sign and Sketchup + Keyshot for the renders :)
5h of work to do this :)
Projects:
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5064193
Defineatly sub'd
Love u  :lol:
Projects:
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5086801
Hello guys, little update!
To my amazement I present the first sponsors of the project:
ModdingStylez
11081178_794757103947972_329610003575465
It will provide the sleeved cables  :)
Thanks Matthias
Projects:
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5109158
Renders are interesting so im in
How would you mode the case? I am looking forward to learn it because I will be doing my own modding on a Wodden Book Shelf :)
First I unmount the front panel and the back panel, next I unmount the plate of the motherboard and i rotate it of 90°.
The rest is work of brackets and some plate :)
New entry
Transcend
They give me the SSD's :)
Thanks Matteo!
Projects:
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5177492
Great news guys
They are going to get the main components of this mod!
A big thank you to CMAlex that despite all the problems could start officially this mod!
Projects:
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5232431
Pending the arrival of the latest components, I begin to introduce the new SSD's flagship home Transcend, the SSD370S.
Some features:
Metal body (Hence the "S" placed at the end of the classical model SSD370)
Capacity from 32GB to 1TB
SATA III 6Gb/s
The box, simple and full impact, it shows immediately a picture of the product and its ability
The bundle is complete:
Bracket;
Double set screws (4 for the bracket, 4 to lock the bracket);
User Manual;
And some illustrations on all other products Transcend.
Protected by an anti-static bag we find our SSD
And here's an overview of how it looks on the ssd mounted bracket
SSDs have given me two, will be configured in RAID 0 for even greater performance (Some benchmarks will put it later)
Thank to Transcend for the opportunity to continue this project and for the sample given me.
For now, I leave you with this beautiful photo.
Projects:
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5276628
What does everyone use to render those and get all the parts etc
My PC:
MOBO: MSI B450 Tomahawk Max, CPU: AMD Ryzen 5 3600, Cooler: BeQuiet! Dark Rock 3, GPU: Gigabyte GTX 1050ti D5 4G, Ram: 16GB (2x8) HyperX Fury DDR4, Case: NZXT S340, Psu: Be Quiet! Pure Power 11 600W , HDD's: WD 1TB Caviar Blue, WD 256GB Scorpio Blue, WD 2TB Caviar Blue  SSD: Sandisk SSD PLUS 240Gb
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5276698
Keyshot ;)
Projects:
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5278948
Keyshot ;)
Thank you
My PC:
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5278979
Uh,boxs
Projects:
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5298211
Meanwhile here is the beautiful cables ModdingStylez being completed.
11640439_838188839604798_1369885224_o.jp
11181557_838188892938126_1338136315_o.jp
Thanks again to Mathias for the kindness and patience he had with me  :rolleyes:
Projects:
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5302462
BIG ENTRY:
CoolerMaster!
Thanks again Alex for giving me this wonderful product of CM's House .
Let's start off with the fans, the Silencio FP 120.
Ben 15, we find especially in CM aio home just because their "generous" blades push a large amount of air.
Opening the package we will immediately in front of the fan. The package is very simple and clean.
But the surprises do not end here, opening further skatole also find a Molex and 2 sets of screws (one rubber and one classic)
Here we can admire in all its beauty the fan with its huge blades
Last grains, but not least, the cable is already black sleeved.
AAAH, my favorite.
CM STORM MECH
Complete of I/O inputs 3.0, aluminummechanical, fully backlit,  fully programmable!
Love at first sight!
Protected by abundant spongy material located at all sides and from a bag ...
Here our Mech
USB 3.0 cable type A / B to eliminate any possible delay during communication with the Rapid Fire Engine 32-bit 72 MHz processor for playing Macro!
In the bundle is ring for the removal of the keys and the key to remove the aluminum part
It is protected by an additional film ...
We find the CM Storm logo shiny continues on aluminum!
Mini-USB connector for an additional power backlight, less than 2 USB 3.0 inputs, microphone input and headphone output.
The mech is also equipped with a useful handle if one wants to carry around (This is to understand how difficult it is be separated from)
The backlight mode is 3 (4 counting the OFF): Totally off, Led near the controls of the game and the macro keys, Total and a wonderful effect FADE IN/OUT of all the LEDs.
The back is clean it is appealing, just like the rest of the keyboard.
Here a programmable macro keys M (i'm already using to insert the IMG tag of the photos, they are tremendously useful when you have to compose more tags same, same thing in games, MMO)
Guys, all for today, tomorrow other news!
Projects:
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5304079
Live from Germany, here is finally completed the great Matthias cables!
11647381_838746549549027_1778892207_n.jp
11653448_838746526215696_1325770490_n.jp
11541319_838746556215693_1661606396_n.jp
Projects:
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5312677
Another pearl Cooler Master, the mouse Reaper! Although it is part of the Aluminium Series characterized backed aluminum
Equipped with a beautiful and elegant protective case
Here is our beautiful mouse, carrying case exposure, the care of these products characterized by their elegance you notice right away.
Like the keyboard, the mouse also is "backlit", LED front and back characterize it, in addition to the fabulous metal roller.
Usb gold-plated for added durability.
What, fabulous!
Projects:
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5314322
Ultimate accessory for today (Tomorrow will come the serious things), Pulse-R. The last component of the Aluminium Series
As for the mouse, also for headphones we are a simple and elegant case
Inside, our headphones.
To get her out we remove the mold that protects and dissolve these wires.
And here our headset with all the accessories included in the package.
There comes a cable with volume control in line to connect our devices to our Headset.
The LEDs (Si, has led) are powered by the USB port.
The microphone, as we have seen by opening the cover, is removable.
The CM Storm logo Engraved above the bow symbolizes that no detail has been overlooked from the house.
Here a preview of the LEDs, both headphone that the controller in line.
For today is all Guys!
Projects:
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5314738
Today is his time guys, here is the V850
It ensures well 840W on the 12V (70A), 80plus Gold Certificate.
The Bundle provided is kept in a handbag.
24 pin | EPS 8 pin | 3 x 3 sata | 2 x 2 molex (+ 4 pin tipo Floppy) |4 x 2 PCI-E 6+2
Projects:
https://linustechtips.com/topic/374273-project-twinforcetower/#findComment-5322053
