Hello here's my build, the previous one had PSU cables but I didn't like them and I don't know what cables I need, will these work with this build? http://www.moddiy.com/products/XFX-Pro-Series-Single-Sleeved-Power-Supply-Modular-Cables-Set-(Black%7B47%7DOrange).html
My build: http://pcpartpicker.com/p/CYJwJx
https://linustechtips.com/topic/374243-custom-cable-modding-need-help/
XFX cables will not work with an EVGA power supply the pin outs will be different. You need cables for your EVGA PSU.
How close is your build's to JayzTwoCents' Skunkworks? The only difference I can see is the 2 hdd instead of ssd's
That time I saved Linus' WiFi pass from appearing on YouTube:
A sudden Linus re-appears : http://linustechtips.com/main/topic/390793-important-dailymotion-account-still-active/
Nope, that's for XFX PSUs.
My recommendation is Cablemod kits. They are PSU replacement cables made for specific brands. This is their Black&orange kit for EVGA G2 and P2 PSUs, which will fit your unit.
http://www.performance-pcs.com/cablemod-e-series-g2-p2-cable-kit-black-orange.html#Details It costs $90 on performance PCs and comes with free cable combs, you can't get better value.
Thank you so much!
