Welcome!
Introduction
Hey , I will now present my project by the name Temptation . As you here will be able to follow from beginning to end . Have had this project in my brain for about a year , has also nearly always wanted to build a really big build and now it's finally here. Having just finished my first project which was mid-tower so I thought to do a little larger building . I dont have buy all the parts for this porject yet because I am waiting for a response from sponsors.
Computer
Have some plans to build in a Silverstone TJ07 , but before I decide it so I wait for the response from some sponsors. Color theme will be orange , gray and black.The color was a bit different but I like the colors anyway. The water cooling will be the largest part of the project where I have a 480mm radiator and 2 reservoirs, which I 'll try to get into the case, then i also have 2x GPU and a CPU who  will be watercooled . I will also make some mods with the cas for example: Midplate in acrylic, remove the hardrivecase and much more
Components
(Will be updated)
GIGABYTE GA-Z87X-OC
GTX 580 1,5GB SLI
1x HyperX SSD 240GB
Sponsored By
________________________________________________________________________________________________________________________________
Thanks to Gigabyte and a special thanks to Josefin on Gigabyte for giving me this:
  • GIGABYTE GA-Z87X-OC
Thanks to Mundi/Icemodz.
  • 1X: 24 pin ATX
  • 1X: 4 pin ATX
  • 1X: 8 pin ATX
  • 2X 8 pin GPU
  • 2X: 6 pin GPU
  • 1X: Cable Combs Clear Double Pack
  • Some lights and little funny stuffs.
PHOTO OF THE PARTS TO THE BUILD IN THE SPOILER
Hello! Here is the first update of this build with some pics on the components and the water cooling. The build going to start soon and i hope you like this so far.
I think this orange motherboard going to be perfect to my color theme orange, black and gray.
Thanks to Gigabyte for this awesome motherboard.
One of two GTX 580.
2 GT fans of 8, you can also se a little bit of the big radiator.
One of two pumps.
Hey! This time have I some small news . I will be away on a trip the whole next week so it will be no updates next week. I can also tell you that Bitfenix will be helping me in this project to make it possible for me, I want to say thanks to BitFenix and Hakan. More about BitFenix and the products that they assisted with will be on a update later.
The PC:
-The case Is on the way home but i cant tell you the name of it, wait and see :thumb:
-A really nice power supply was the photo bench today , as you can see in the pictures below.
-I will Start a little bit with the casemoding as soon as possible.
let the image speak for itself :)
Best Regards
Gustav
Hallo everyone! As I tell you last time that i be away this week was set because of the weather, but here 's a quick update with just one picture of a little sketch I made how it should look like. Everything will of course not look like this , but most of it.
The case , fans and some other fun stuff from BitFenix ​​arrives tomorrow , so hopefully I 'll take a look and take some pictures of it .
Now the picture:
I Can´t wait to i can start building in this awesome case :thumb:
Hey again!
This time it was a very tight update , I was told today that the cables and some other things from Icemodz who are sponsering the project is now way home :) So definitely you should get a little sneak peek of the cables Icemodz send to me. The pictures I received from Mundi looks awesome and the look of them is really good,more pictures will ccome when I have the cabels. Have to say that Mundi on has done an awesome job !
Icemodz
Good evening everyone!
This time I have cables and some candy from Icemodz who sponsored the project . The cables are really cool and looked very good and the quality is awesome. Sleeve was not too thin and it cover the cable very good, you can absolutely see that there are sleeved really advance! Highly recommend for these people who dont like to sleeve by themselves.
Team Group has also sponsored with a couple of really awesome 8 GB memory with 2400MHz! Which I think will be perfect for the build , some more power than ordinary 1866mhz ;)
I had also purchased a Intel Core i5 4690K for the build.
Pictures will be below.
https://linustechtips.com/topic/374137-project-temptation/
Here comes all the parts to the build:
One of two GTX 580.
One of two pumps.
The PC:
Best Regards
Gustav
Now the picture:
Hey again!
Icemodz
https://linustechtips.com/topic/374137-project-temptation/#findComment-5060788
That is nice! Goodluck with your build!
https://linustechtips.com/topic/374137-project-temptation/#findComment-5060806
Nice ~ I like the colour scheme
CPU: i5 4670k @ 3.4GHz + Corsair H100i      GPU: Gigabyte GTX 680 SOC (+215 Core|+162 Mem)     SSD: Kingston V300 240GB (OS)      Headset: Logitech G930
Case: Cosair Vengance C70 (white)                RAM: 16GB TeamGroup Elite Black DDR3 1600MHz       HDD: 1TB WD Blue                              Mouse: Logitech G602
OS: Windows 7 Home Premium                       PSUXFX Core Edition 750w                                                Motherboard: MSI Z97-G45               Keyboard: Logitech G510
https://linustechtips.com/topic/374137-project-temptation/#findComment-5060813
um shorten your message plz damn
Done. :P
EDIT: use spoiler. Makes it better.
https://linustechtips.com/topic/374137-project-temptation/#findComment-5060826
Good evening! Today was time to start mod the case , the hard drive cage is removed and some other simple things . Even a  mockup of the components was catched in the picture.
The next update will be more on the radiators and also a small secret mod, more of that later!
Now to the pics:
Hard drive cage is removed.
https://linustechtips.com/topic/374137-project-temptation/#findComment-5169440
  • 2 weeks later...
  • 1 month later...
Hey! has finally becomemy first mod here at Linustechtips. Then I always had a great and a little of the larger battle that I would not have to take on the LAN so I decide me to turn to big! Then it became a modded Antec 1900.
Hardware
GIGABYTE GA - Z87X - OC
Intel Core i5 4690K
HyperX SSD 240GB
2 x 500 GB Random
Corsair RM1000
GTX 580 SLI 1,5GB
8GB Team Group Xtreem White
I want to thank my sponsors:
Gigabyte
Icemodz
Team Group
Cooling Stuff
Note , images will be updated because
https://linustechtips.com/topic/374137-project-temptation/#findComment-5678281
