Hi guys,  I have been looking at building a video editing and little gaming for the last few days.  I've never built my own rig, but have helped a friend before.
Here is a link to the current state of the build in pc part picker = http://pcpartpicker.com/p/fqfdP6
My Budget is about $600
I still confused about the graphics card. I'm working with Adobe After Effects, Photoshop, Illustrator and I want to play GTA V and Watch Dogs. I know for some reason Nvidia is good for Adobe Application, because of the CUDA cores. So what graphics card is match with my work and games?
Thanks!
https://linustechtips.com/topic/374108-help-first-time-building/
Hey its not worth it to build a rig with a 600budget especially for a videoediting and gaming rig its just not worth it
The Y.E.T.I. is in progress?Whaaat? (modding aproach&build log)->http://linustechtips.com/main/topic/355618-project-yeti-first-build/
[READ THE COC BEFORE POSTING][Check twice cut once][NZXT rules:D][Dremel is Love Dremel is Life][COOKIES ARE GREAT][LOGIC]
https://linustechtips.com/topic/374108-help-first-time-building/#findComment-5060445
My system is around £500. I can edit and play games at 720p@60fps.. while using a gtx 560.
https://linustechtips.com/topic/374108-help-first-time-building/#findComment-5060452
I recommend the GTX 960 for a budget like this. However you might want to wait till the price falls a bit. I got my GTX 760 for £140, it's now £210.
If you want my attention, quote my post or I will not see it. I ignore builds that do not use PCPartPicker.
If I have solved/answered your question, please press "mark solved" to make it easier for the rest of the community find the answer
https://linustechtips.com/topic/374108-help-first-time-building/#findComment-5060453
Thanks!
@X_Rated_Box said you aren't going to get any performance for what you want. Save up some money so you can get some good hardware for what you are wanting.
https://linustechtips.com/topic/374108-help-first-time-building/#findComment-5060461
This i what i meant:D with this budget you are not going to achieve what you want to achieve
https://linustechtips.com/topic/374108-help-first-time-building/#findComment-5060474
720p is a thing of the past, it's nothing to be proud of. You would be lucky to even boot up GTA, if you could play it, you'd be lucky to push 30fps on medium.
https://linustechtips.com/topic/374108-help-first-time-building/#findComment-5060479
Well for editing I understand go with 720p because to me for youtube there is hardly a difference for 1080 and 720, so why take the extra time to render 1080. But the playing part I understand what you are going with here.
https://linustechtips.com/topic/374108-help-first-time-building/#findComment-5060509
I don't play GTA 5. I've finished the game on console Also online is stupid Everyone leaves heists and no one finishes them. Who cares if 720p is old. At least I play games. I don't have 1080p monitor. I've got 900p which is fine for me.
https://linustechtips.com/topic/374108-help-first-time-building/#findComment-5060514
For $20 more you can get a much better PSU
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($98.99 @ Newegg)
Motherboard: Gigabyte GA-970A-DS3P ATX AM3+ Motherboard  ($66.98 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($57.99 @ Micro Center)
Power Supply: SeaSonic 600W 80+ Bronze Certified ATX Power Supply  ($56.98 @ Newegg)
Total: $612.66
Generated by PCPartPicker 2015-05-26 09:28 EDT-0400
For video editing, minimum 16GB RAM, so I sacrificed the SSD for this
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/374108-help-first-time-building/#findComment-5060714
