Manufacturers dont see 1GB as 1024MB they see it as 1000MB. That may be why ?
My Build  CPU: AMD Phenom II X4 955@4.1@Ghz Mobo: Asus M5A99x Evo R2.0 GPU: Asus 7870T @1.25GHz Core 5.5GHz Mem Ram: Kingston HyperX@ 1600 9-9-9-24 CPU Cooler: H80 Push/Pull Noctua NF-P12  SSD: Samsung 128GB 840 PRO HDD: Mix of drives which add up to 5.6TB SoundCard: Asus xonar DGX PSU: Corsair HX650 + alchemy cables Case: R3 with the rest of the fans being fractel fans.
Im A Snake.....
https://linustechtips.com/topic/37398-disk-space-problem/#findComment-480954
Get WinDirStat, it is a free program that lets you easily see what files take up how much space any where your space may be going.
Intel 3570K - MSI GTX 660Ti 3GB OC Edition - 16GB Corsair LP RAM - ASRock Extreme4 Motherboard - Corsair HX850 - Adata Premier Pro SP900 120GB SSD with Windows 7 - Seagate Barracuda 1TD HDD - Seagate Barracuda 500GB HDD - Thermaltake Frio CPU Cooler - CM Storm Enforcer Case - Macbook Pro Early 2011 Laptop
https://linustechtips.com/topic/37398-disk-space-problem/#findComment-480960
thats what confuses me
Its just how they do it if you buy a 1TB drive its like 930GB maybe less.
Im A Snake.....
https://linustechtips.com/topic/37398-disk-space-problem/#findComment-480984
But that wouldn't explain a 60gb gap, that barely adds up to anything, as you said it was 70gb for a tb, a 120gb drive has like 118gb in it, that wouldn't really change this too much
https://linustechtips.com/topic/37398-disk-space-problem/#findComment-480992
http://gyazo.com/d0d099880ce718d84364d6c98b7bb22f
http://gyazo.com/36b8366d16722efde9f3136ac5766c77
thats what it adds to
https://linustechtips.com/topic/37398-disk-space-problem/#findComment-480999
Check in windows for the size of the partition, and remember that when windows talks about GB it means GiB (1024 MiB). Also, if windows is installed on it, program data takes up a lot of space but is hidden, along with quite a few other folders. In folder options, turn on show hidden files and folders and turn off hide protected os files then add it up again. It should be closer
HTTP/2 203
https://linustechtips.com/topic/37398-disk-space-problem/#findComment-481012
You should try windirstat because of the picture interface, it lets you browse your files really easily to see what takes up the most space. Also as I said above, you get 118gb with that ssd, so the 24mb difference means you lose 2gb
Edit: as colonel_mortis said above make sure that you have show hidden files checked, then I would run windirstat and look through the size of your files for that missing amount (windirstat will show you the windows files too)
https://linustechtips.com/topic/37398-disk-space-problem/#findComment-481015
