Which Cpu will bottleneck less for games?
Go to solution Solved by Glenwing,
Even for a game that only uses 1 core do you think the 1055t will perform better?
Yes. The single-threaded performance is pretty equal.
I am having trouble deciding between using one of these 2 computers with a Gtx 580, I know it will bottleneck, I just cannot seem to be able to find which will bottleneck less. I think the Core 2 Quad is better with the overclock for lower threaded games but just looking for a second opinion.
Phenom II 1055t @ stock clocks ( I can try to overclock it )
Asus M4A88TD-V Evo/Usb3
2x4gb ddr3 1333mhz
.....or.....
Core 2 Quad Q6600 @ 3.4ghz
Asus P5Q SE
4x2gb ddr2 1066mhz
Both have 750w psu.
Again I know it will bottleneck, this is and will not be my main computer. I have a 3570k and a Gtx 780 already. This is just for fun to play with and leave connected to a tv.
Thanks!!!!!
Windows 10 Build: 3570k @4.5ghz, ASrock Z77 Extreme 4, 8gb ddr3, R9 390,  120gb HyperX 3k, 500gb Western Digital Blue
Windows XP Build: Pentium D Extreme Edition 965, 4gb ddr2, Gt 120, 250gb Western Digital
Windows 98 SE Build: Pentium III 650mhz Slot 1, Asus P2B, 128mb PC100, Matrox G400, (Voodoo 2 12mb) x 2 SLI, 80gb Western Digital
https://linustechtips.com/topic/373943-which-cpu-will-bottleneck-less-for-games/
For anyone who is actually interested. I was able to check the card in both of the setups mentioned above. All I did was a quick test with unigine valley benchmark.
q6600 @ 3.4ghz             (Second Run)
fps:       33                             33.1
min:     15.6                           17.4
max:     57.2                          59.2
score:  1379                          1384
1055t @stock
                                    (Second Run)
fps:    32.1                       32.3
min:   14                          15.9
max:   57                         57.6
Score 1344                     1350
At stock clocks the 1055t performs about the same as the q6600 overclocked to 3.4ghz. I will be using the 1055t with the gtx 580 in hopes of being able to overclock. Thanks to those who recommended the 1055t, I wouldn't have tested it otherwise.
