Do you think my system would get to hot in this case?
Solved by Aniallation,
I will most likely feel up all the fan spots.
Then you shouldn't have an issue with heat, especially if you add in the optional(?) 200mm fan
Featured Topics
Hey_AND1 ·
Posted in Peripherals0 -
INotPablo ·
Posted in New Builds and Planning1 -
1
EdoTensei ·
Posted in Graphics Cards2 -
Idkwhattodowithmylife ·
2
1
