Hi,
This is my first ever build and I'm planning on buy the stuff at the end of the week, have i missed any thing off or is there a better alternative i could use.  Also will it all work together???
PSU EVGA SuperNOVA 1200 P2 ATX Power Supply - 1200W 80 PLUS Platinum Fully Modular PSU
Optical Pioneer BDR-209EBK 128GB 16x Multi Layer Blu Ray Re-Writer - Black - Full Retail Boxed
Motherboard ASUS ROG RAMPAGE V EXTREME/U3.1 Intel X99 (Socket 2011-3) Motherboard
CPU Intel Core i7-5820K 3.30GHz (Haswell-E) Socket LGA2011-V3 Processor - Retail
GPU ASUS GeForce GTX 980 ROG MATRIX PLATINUM 4GB GDDR5
Case Cooling Corsair Air Series SP120 PWM Quiet Edition High Static Pressure Fan Twin Pack
CPU Cooling Corsair Hydro Series? H110i GT 280mm Extreme Performance Liquid CPU Cooler
RAM G.Skill Ripjaws 4 Red 32GB (4x8GB) DDR4 PC4-21300 2666MHz Quad Channel Kit
Case Corsair Obsidian Series 900D Super Tower case, Black, Windowed
OS SSD Samsung 850 Evo Basic 500GB Solid State Hard Drive 2.5" Basic Kit with Data Migration Software - Retail
Storage HDD WD Black 3TB 64MB Cache Hard Disk Drive SATA 6 Gb/s 168MB/s 7200rpm - OEM
Audio Card Asus ROG Xonar Phoebus Gaming Set
Controller Asus ROG Front Base Dual Bay Gaming Panel - Fan & System Controller
OS Microsoft Windows 8.1 Pro Operating System - 32/64 Bit - Full Retail
Peripherals ASUS Vulcan Pro Gaming Headset ROG
Gaming Audio Series SP2500 High-power 2.1 PC Speaker System
Asus ROG Swift NVidia GSYNCTM 27 Inch WQHD LED Monitor
MAD CATZ S.T.R.I.K.E. 7 Gaming Keyboard
MAD CATZ M.M.O. 7 Laser Gaming Mouse - Black & Orange
Logitech Webcam C930 E Webcam
Once i have it all will take some pictures as i build it not into the making videos.
https://linustechtips.com/topic/373447-first-build-help/
Use PCPartPicker to determine any possible compatibility issues
If you want my attention, quote my post or I will not see it. I ignore builds that do not use PCPartPicker.
If I have solved/answered your question, please press "mark solved" to make it easier for the rest of the community find the answer
https://linustechtips.com/topic/373447-first-build-help/#findComment-5051705
3 things...
You don't need a 1200W PSU, unless going for tripple titans or more,
It's not a very balanced build (you havn't stated usage)
In that price-range I'd be looking at sli 980's and a larger and faster SSD
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
https://linustechtips.com/topic/373447-first-build-help/#findComment-5051722
3 things...
Would i be better changing the GPU for a SLI configuration.
Plan on using it for gaming and some photo editing but would like some future proofing.
Budget is about £3500.
https://linustechtips.com/topic/373447-first-build-help/#findComment-5051760
Your going way over what you need..
I would say Spend £1500 - £2000 and save the rest for a future buy.. There is no future-proofing at the moment. The chipsets and sockets for the CPU changes and then it's a full build.
I would say get an 850W decent PSU, a z97 board and a 4790k & 16-32GB ram (if small size and number of editing, 8 is fine) with a 500GB ssd and 2 HDD's (make them mirror each other for data security, Also have external for back-ups) and a single 980..
Then in about 2-3 years get a new graphics card.. In a further 2-3 years replace the whole thing. Cost the same, perform pretty much the same (for your usage) and last longer on the same budget.
P.S, follow your own topics to get notifications.
https://linustechtips.com/topic/373447-first-build-help/#findComment-5051811
This is what i could do within your budget, didn't include peripherals though, there's still £1400 left to be spent
CPU: Intel Core i7-5930K 3.5GHz 6-Core Processor (£431.94 @ Aria PC)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler (£79.99 @ Amazon UK)
Motherboard: MSI X99S Gaming 7 ATX LGA2011-3 Motherboard (£189.99 @ Dabs)
Memory: Corsair Vengeance LPX 16GB (4 x 4GB) DDR4-2400 Memory (£141.79 @ Scan.co.uk)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive (£145.98 @ Aria PC)
Storage: Toshiba 3TB 3.5" 7200RPM Internal Hard Drive (£71.79 @ Amazon UK)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE 3X Video Card (2-Way SLI) (£429.98 @ Novatech)
Case: Phanteks Enthoo Pro ATX Full Tower Case (£85.93 @ Scan.co.uk)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply (£94.99 @ Amazon UK)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) (£75.34 @ CCL Computers)
Monitor: Acer XB270HU bprz 144Hz 27.0" Monitor
Total: £2177.70
Generated by PCPartPicker 2015-05-25 14:45 BST+0100
https://linustechtips.com/topic/373447-first-build-help/#findComment-5051891
Total: £2177.70
This looks great.
I have not got a clue about pc creation I'm one of those that if its expensive it must be good!
https://linustechtips.com/topic/373447-first-build-help/#findComment-5051936
This looks great.
To a point, but there is also a point where you just start wasting money.
Here is a modified version of that build.
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  (£303.54 @ Aria PC)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  (£100.51 @ CCL Computers)
Memory: Kingston FURY 16GB (2 x 8GB) DDR4-2133 Memory  (£135.99 @ Amazon UK)
Video Card: Sapphire Radeon R9 290X 8GB Vapor-X Video Card (2-Way CrossFire)  (£375.78 @ Dabs)
Power Supply: XFX ProSeries 1050W 80+ Gold Certified Fully-Modular ATX Power Supply  (£125.24 @ More Computers)
Monitor: Acer XG270HU 144Hz 27.0" Monitor  (£378.25 @ Amazon UK)
Total: £2415.87
Generated by PCPartPicker 2015-05-25 15:36 BST+0100
It may look like the price is higher on this build but the other didn't have a price on the monitor.
https://linustechtips.com/topic/373447-first-build-help/#findComment-5052212
This looks great.
That is usually one way to empty your wallet. You do get what you pay for with some items. Other things are just overpriced.
Are you going to be building this pc yourself ?
https://linustechtips.com/topic/373447-first-build-help/#findComment-5052503
Total: £2177.70
That total price is way out when you click on the link. You are still under budget, but the total is £2.9K rather than £2.1K. For some reason the monitor hasn't been included in the price.
https://linustechtips.com/topic/373447-first-build-help/#findComment-5052676
I would go with something like this.
The i7 4790K is a great all round cpu. If you look at gaming benchmarks you will see that it matches/beats the 5820K in most games. By the time a 6 core cpu is standard for gaming then things will have moved on anyway. There is also a '2 for 1' offer on Gigabyte Black edition boards that lets you swap the board for a new one within 3 years.
See here - http://bk.gigabyte.eu/EN_bk_UK_Ireland.html
There is also a cashback offer if you buy a cpu/board bundle - https://toptechcashback.com/uk/en/pages/cpumb/qualifying?utm_source=Overclockers+UK+Newsletter&utm_campaign=4c4a227cf4-Intel_Cashback_CW215_22_2015&utm_medium=email&utm_term=0_c199b69777-4c4a227cf4-212867289
The Titan X will easily handle 1440p. It will even do a good job at 4K. There is room for a 2nd card if you ever want to SLI.
I haven't included the peripherals so you will need to add them in.
If you are not in a rush to buy anything then the new cards should be here pretty soon (June time).
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  (£262.00 @ Amazon UK)
CPU Cooler: Corsair H110i GT 113.0 CFM Liquid CPU Cooler  (£99.98 @ Aria PC)
Motherboard: Gigabyte GA-Z97X-GAMING 7 ATX LGA1150 Motherboard  (£124.76 @ Scan.co.uk)
Memory: Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1866 Memory  (£99.16 @ Scan.co.uk)
Storage: Crucial BX100 500GB 2.5" Solid State Drive  (£139.98 @ Amazon UK)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  (£78.97 @ CCL Computers)
Video Card: Gigabyte GeForce GTX Titan X 12GB Video Card  (£824.98 @ CCL Computers)
Case: Phanteks Enthoo Luxe ATX Full Tower Case  (£111.84 @ Scan.co.uk)
Monitor: Asus ROG SWIFT PG278Q 144Hz 27.0" Monitor  (£563.99 @ Aria PC)
Total: £2475.99
Generated by PCPartPicker 2015-05-25 16:37 BST+0100
https://linustechtips.com/topic/373447-first-build-help/#findComment-5052778
Motherboard: Asus SABERTOOTH Z97 MARK 1 ATX LGA1150 Motherboard  (£181.92 @ Amazon UK)
Memory: Kingston Fury Black Series 16GB (2 x 8GB) DDR3-1600 Memory  (£85.12 @ CCL Computers)
Video Card: EVGA GeForce GTX Titan X 12GB Video Card  (£888.00 @ Aria PC)
Case: Corsair 330R Titanium Edition ATX Mid Tower Case  (£79.94 @ More Computers)
Optical Drive: Samsung SH-224DB/RSBS DVD/CD Writer  (£12.36 @ CCL Computers)
Monitor: Acer XB270HU bprz 144Hz 27.0" Monitor  (£749.99 @ CCL Computers)
Keyboard: Corsair Vengeance K95 Wired Gaming Keyboard  (£119.99 @ Novatech)
Mouse: Corsair Sabre Wired Laser Mouse  (£34.60 @ Ebuyer)
Headphones: Kingston HyperX Cloud II 7.1 Channel Headset  (£66.35 @ CCL Computers)
Speakers: Corsair Gaming Audio Series SP2500 232W 2.1ch Speakers  (£175.00 @ Amazon UK)
Total: £3118.57
Generated by PCPartPicker 2015-05-25 17:02 BST+0100
Call me old school but I'd rather stick with 4790K to get a Titan X
Scarlet KnightIntel Core i3 6100 || Antec A40 Pro CPU Cooler || MSI Z170A Gaming M5 || Kingston HyperX 16GB DDR4-2133MHz || Samsung 850 Evo 120GB || Seagate Barracuda 1TB || Gigabyte G1 Gaming R9 390X 8GB || Seasonic M12II 620W || In Win 503 || Corsair Strafe || Steelseries Kinzu V3 MSI Edition || Dell UltraSharp U2414H || Xiaomi Alumunium Mouse Pad (S)
#Gadget:
Phone: BlackBerry Classic Q20, Samsung Galaxy Note 4 S-LTE SM-N916S
Console: PlayStation 4 500GB CUH-1206A
Tablet: iPad Air 2 16GB Wi-fi Only
Laptop: MSI GE62 (i7 4720HQ || 8GB DDR3 || NVIDIA GTX960M || Samsung 650 EVO 120GB + 1TB HDD)
In-ear Monitor: Xiaomi Piston 3.0
https://linustechtips.com/topic/373447-first-build-help/#findComment-5052889
Hi,
Guys thank you for all your help. Had a look at it all and this is the build that i am going to do.
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  (£305.00 @ Scan.co.uk)
CPU Cooler: Corsair H110i GT 113.0 CFM Liquid CPU Cooler  (£100.94 @ Scan.co.uk)
Motherboard: MSI X99S Gaming 7 ATX LGA2011-3 Motherboard  (£200.39 @ Scan.co.uk)
Memory: Corsair Vengeance LPX 32GB (4 x 8GB) DDR4-2400 Memory  (£273.98 @ Scan.co.uk)
Storage: Samsung 845DC EVO 480GB 2.5" Solid State Drive  (£239.38 @ Scan.co.uk)
Video Card: MSI GeForce GTX 980 4GB Twin Frozr Video Card (2-Way SLI)  (£454.78 @ Scan.co.uk)
Case: Cooler Master Cosmos II (Black) ATX Full Tower Case  (£299.99 @ Scan.co.uk)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  (£106.62 @ Scan.co.uk)
Optical Drive: Pioneer BDR-209DBK Blu-Ray/DVD/CD Writer  (£57.79 @ Scan.co.uk)
Monitor: Acer XB270HA 144Hz 27.0" Monitor  (£367.52 @ Scan.co.uk)
Speakers: Corsair Gaming Audio Series SP2500 232W 2.1ch Speakers  (£178.68 @ Scan.co.uk)
Total: £3534.93
Generated by PCPartPicker 2015-05-25 19:50 BST+0100
Yeah its a little over my budget but that because i seen the Cosmo II and like the idea with the covers to keep little fingers out when I'm not on it.
You may all shout at me for ordering at the same place but i find its so much easier if i can get it all in one go with my job.
https://linustechtips.com/topic/373447-first-build-help/#findComment-5054252
Hi,
Total: £3534.93
That SSD is a bit of a waste for a gaming/home pc as it is designed for use in workstation pc's. I would stick with the 850 Evo or the Crucial BX100/MX100/MX200.
You don't need 32GB Ram.
WD Black drives are overpriced as well. A Seagate would do the same job for less.
Why two 144HZ Monitors ? And with this budget you should be aiming for 1440p or even 4K
https://linustechtips.com/topic/373447-first-build-help/#findComment-5054738
The SSD is a 850 Evo didn't notice that must have selected the wrong one.
Been looking at the ASUS PB287Q 4K Monitor, and cannot really think of a reason why i would need 2 for gaming, 3 yes but not 2.
Also reduced the ram to 16GB.
https://linustechtips.com/topic/373447-first-build-help/#findComment-5055262
