Audio popping/static.
Go to solution Solved by Trik'Stari,
Apparently all I needed was a windows update and a restart, because it's gone now.
Weirdness.
So. I'm getting this weird issue, when I am streaming something either through spotify, or watching netflix, or even just watching youtube, and I load or even refresh a webpage, my audio lags and gets staticy, pops, etc, and even video playback lags and stutters and slows down.
I've update all of my drivers, audio and video alike, and problem persists. I am worried that it could be an issue with my motherboard sound, but I'm not sure how to proceed in pinning down exactly what this issue is.
Dubs are better than subs
https://linustechtips.com/topic/373052-audio-poppingstatic/
what os do you use
try downloading the dpc latency checker
Abigail: Intel Core i7-4790k @ 4.5GHz 1.170v / EVGA Nvidia GeForce GTX 980 Ti Classified  / ASRock Z97 Extreme6 / Corsair H110i GT / 4x4Gb G.Skill Ares 1866MHz @ CAS9 / Samsung 840 EVO 250Gb SSD / Seagate Barracuda 1TB 7200RPM / NZXT H440 Blue / EVGA SuperNOVA 750w G2
Peripherals: BenQ XL2411z 24" 144hz 1080p / ASUS VG248QE 24" 144Hz 1080p / Corsair Vengeance K70 RGB / Logitech G502 / Sennheiser HD650 / Schiit Audio Modi 2 / Magni 2 / Blue Yeti Blackout
https://linustechtips.com/topic/373052-audio-poppingstatic/#findComment-5047516
I'm using windows 7.
I'll check that out. What does it do?
checks for latency in audio streams to determine if latency is causing the sound issue
i had a popping/static/skipping issue before
what mobo?
https://linustechtips.com/topic/373052-audio-poppingstatic/#findComment-5047557
Gigabyte GA-z97mx gaming-5
I had a similar problem on my old gtx660 (using the same motherboard) but it went away when I switched to my gtx970
https://linustechtips.com/topic/373052-audio-poppingstatic/#findComment-5047579
maybe interference is causing this. try using an external dac or an external sound card
CPU:  i7 5820k  @4.0Ghz Cooler: Thermaltake Nic C5 Motherboard: MSI X99A SLI PLUS  Ram: 8 gb @2133Mhz GPU: Gigabyte GTX 970 G1 @1560  Case: Proprietary Sun Ultra 24  Storage: HyperX 120gb & 1 TB WD Green PSU: Cooler Master 550w
https://linustechtips.com/topic/373052-audio-poppingstatic/#findComment-5047580
Well, I can confirm that this is not an issue exclusive to streaming, as it occurs with music I have on my HDD playing through Windows Media player.
Any thoughts? I'd try a sound card of some kind, if I had one.
https://linustechtips.com/topic/373052-audio-poppingstatic/#findComment-5047748
