Keep focus while shooting
Solved by Dredgy,
Keep stopping the lens down, by the time you get to F22 everything should be in focus. A wide angle lens will help too.
Or pull focus manually, a follow focus might help, but for continuous shooting fast moving subjects it will require a fair bit of skill, but allows you to constantly change what is in focus as opposed to keeping everything in focus all the time.
