its probably the type of wifi
alot of adapters don't like certain types of config
reset the router to default wifi settings
then try
then once you get connected
slowly change the settings back to how you had them..and find out what is causing the issue
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/372784-wifi-problem/#findComment-5044286
then try
I did Factory reset and nothing :/
https://linustechtips.com/topic/372784-wifi-problem/#findComment-5044297
