Currently looking at the EVGA SC ACX 2.0, and the Gigabyte G1 Gaming.
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/372451-best-non-reference-970/
They're both great cards. I think the ACX 2.0 looks better but the G1 will likely overclock better and maybe cool better as well. Lays can tell you about the G1 and Darkman can tell you about the ACX 2.0 (FTW+ though instead of SC).
https://linustechtips.com/topic/372451-best-non-reference-970/#findComment-5040738
I'd go with G1 Gaming because it overclocks well and cools well. Although the SC ACX 2.0 is not a bad card either.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/372451-best-non-reference-970/#findComment-5040783
Stay away from the ACX 2.0 SC.  The design on the heatsink is just fundamentally bad and the iron chokes it uses are among the worst on the market and produce tons of inductor noise.  However, the ACX 2.0 SSC+ and FTW+ models are the cards EVGA should have made from the start. I would easily recommend those two over anything else on the market because they fix all the problems the original models had with heatsink design, beefed up the power delivery, and added dual-bios switches.
CPU: Intel i7 4790k @4.7ghz - RAM: HyperX Savage 16GB DDR3 Memory @2400mhz - GPU: Nvidia GTX 970 3.5GB @1500mhz - Mobo: Gigabyte Gaming 7 Z97 - Storage: Win10 on 240GB HyperX Predator m.2 SSD, - Ubuntu w/ Gnome 3 on 80GB OCZ Vertex 3 - 500GB Samsung 850 Evo Game Installs - 5TB mass storage - Monitor: 21:9 3440x1440 LG 34UM95 - PSU: Corsair RM 750w - Case: Silverstone FT01 - Cooling: Custom Water Loop
https://linustechtips.com/topic/372451-best-non-reference-970/#findComment-5040851
thanks all for the replies. I'll just flip a coin to see which one to get!
https://linustechtips.com/topic/372451-best-non-reference-970/#findComment-5041380
