Want to build my first computer budget is not a problem, where thinking about something like this:
Corsair RM1000 1000watt 80 PLUS Gold ---> seasonic 1000w psu (after feedback)
Kingston HyperX Savage 480GB 2.5" SATA-600 ---> intel NVME ssd (after feedback)
Anything I chould consider changing, or would be cool to have?
CPU: i7-5960X COOLER: Fractal Design Kelvin S36 GPU: Asus GTX T MOBO: Asus Maximus VI Hero  RAM: Corsair Vengeance 16GB 2800MHz PSU: Seasonic 1000w STORAGE: Intel® SSD 750 1.2 TB Case: NZXTH440
https://linustechtips.com/topic/372112-need-advice-on-first-computer/
How much have you got to spend on it and what are you using it for?
Welcome to the forum and don't forget to follow your own topics @Dibba
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
For a first computer, that is a VERY nice build you have.
That time I saved Linus' WiFi pass from appearing on YouTube:
A sudden Linus re-appears : http://linustechtips.com/main/topic/390793-important-dailymotion-account-still-active/
Thank you! Budget is not a big factor, want to run ultra on all games @ADZ_123_!"£
looks nice tho a couple changes
seasonic 1000w psu
and a new intel NVME ssd
Ty will change to seasonic 1000w, not really sure about the NVME (because of color) but the speed makes me consider it!
What resolution? I'll presume 1080p
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ SuperBiiz)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($89.99 @ Best Buy)
Motherboard: Gigabyte GA-Z97MX-Gaming 5 Micro ATX LGA1150 Motherboard  ($96.99 @ SuperBiiz)
Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory  ($59.98 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($97.95 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.60 @ SuperBiiz)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($309.99 @ SuperBiiz)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($102.99 @ SuperBiiz)
Power Supply: XFX XTR 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($94.99 @ Amazon)
Total: $1121.47
Generated by PCPartPicker 2015-05-23 10:24 EDT-0400
Total: $1121.47
Looks like a good setup. But want to go for 4k in the future with sli, would 980 be a better option
then?
then?
Yeah. here's a REALLY sexy PC
Video Card: EVGA GeForce GTX 980 4GB Superclocked Video Card  ($594.98 @ Newegg)
Total: $1406.46
Generated by PCPartPicker 2015-05-23 10:34 EDT-0400
then?
you can ignore his post..he basically cut your pc specs in half
if budget is no issue..then you defiantly want a 2011-3 setup
dual 980s would give you better performance then a titan...but would also come with other problems
also you probably wanna wait for the 980TI coming out very soon
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
Thanks, will not buy for a month. So worth the waiting. But dual titans, are they worth it?
personally no....maybe when 4k gaming is mainstream
It's a good set up but 1,000 watts is a little much.  Save yourself some money and go with a 750 or 850 watt
if he's gonna sli in the future tho...he will want the extra power
True, want the option to sli in the future. Will keep you updated with pictures, when I build it
