I have 2 monitors that I want to mount on a wall but they don't have holes or anything in the back to mount them onto a traditional wall mount. Do you think I could get some L-Shaped brackets and bend one side and screw it into the wall and have the monitors sitting on 2 of them?
This is a shitty diagram because I can't really explain it that well xP http://prntscr.com/78a19i
CPU: i7 2600k @4.2GHz GPU: GTX 660 Power Supply: EVGA SupernovaNEX 750W 80+ Bronze RAM: 32GB G. Skill Ripjaws X
https://linustechtips.com/topic/371758-wall-mount/
Theoretically it would work as long as the bezels can take the weight but it would limit you to one direction and a tilt upwards since you can't move it around like a traditional monitor mount. What mointors do you have there are others who have modified mounting points to the original monitor stand or bolted through the plastic back.
https://linustechtips.com/topic/371758-wall-mount/#findComment-5032885
