charger types
Go to solution Solved by dragoon20005,
it will still draw 1A
It'll charge faster, shouldn't cause any damage.
Project Tomahawk:
CPU: Intel Core i7 4790k
Motherboard: Asus Maximus VII Hero
CPU Cooler: Corsair H100i
Memory: 16GB Kingston HyperX Fury 1866 Mhz
GPU: Asus Strix RX 480
PSU: Corsair RM1000
Storage: 2x Western Digital 2TB Enterprise + 240GB Crucial M500 SSD
Case: Corsair Air 540
Additional: Cablemod C-Series black/red kit, SP120, AF140 and AF140 w/ red LED's all around
Project Frankenstein:
CPU: AMD FX 6100
Motherboard: MSI 970 SLI Krait Edition
CPU Cooler: Cooler Master Hyper 212 EVO
Memory: 8GB G.Skill Ripjaws X 1866 Mhz
GPU: MSI R9 280 3G Twin Frozr
PSU: Seasonic M12II EVO 620W
Storage: Western Digital 1TB Enterprise + 240GB Partiot Torch SSD
Case: Fractal Design Define S
Sheila (Server):
Dell R210:
CPU: Intel Xeon x3450
Memory: 12GB Crucial ECC 1600 Mhz
Storage: Seagate 3TB Constellation
Marvin (Server)
Dell R210ii
CPU: Intel Xeon E3 1230v2
Memory: 12GB Crucial ECC 1600Mhz
https://linustechtips.com/topic/371449-charger-types/#findComment-5028860
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/371449-charger-types/#findComment-5028864
If the phone is only designed for 1a charging capability, The charger will regulate the power flow to 1amp to avoid over charging the phone outside it's designed specs. It will only charge at 2.1amps if the phone is designed for it.
It's the same if you were to charge a phone with one of those quick charge adapters. It will never use the fast charging methods unless the device was designed for it.
https://linustechtips.com/topic/371449-charger-types/#findComment-5032210
so no way to fast charge it right :( :(
https://linustechtips.com/topic/371449-charger-types/#findComment-5041974
yes you are just limted to 5v 1A
https://linustechtips.com/topic/371449-charger-types/#findComment-5043835
