I just bought this GTX 460 , i got a 500W PSU that i dont know wht model is it or anything about it i just know it's 500W
I see on forums ppl talking about 12v lines and amps and that made me confused cauz i dont know what is that( Is it really important?)
I m ganna buy a molex>pcie 6 pin convertor tomorrow so i test this card, i really need to know if the amps and 12v line is important or it's just about how many watts the graphic card need?
https://linustechtips.com/topic/3713-gtx-460-help-plox/
Someone on other forum told me it's not enouf (I'm guessing you made a typo on the +12V rating... it can't be 2.0 amps, I think it might be 20.0 amps? Anyway, that's still too low, you'd need to replace it.
It's often a dead giveaway when a power supply doesn't have any 6-pin connector for graphics cards in the first place, that it doesn't have enough +12V amps for cards that need a dedicated connector. Sometimes a molex->6-pin adapter will do the trick, but usually not.
Also, I'm pretty sure the GTX 460 requires TWO 6-pin connectors, not just one! So you'll want a power supply that provides two connectors (like the ones I've linked below):)
And few others told me it ll work fine i m really confused and i dont really have much $$ left to buy a new PSU ;C
https://linustechtips.com/topic/3713-gtx-460-help-plox/#findComment-46080
