I'm building a pc and I will be running a nividea gtx 970 atx 2.0. I'm in the market for some over clocking as well. Will a 750 watt power supply be enough? It should be more than fine but a few sites have said I need something along the lines of a 800 watt. Any help is appreciated!
https://linustechtips.com/topic/370936-do-i-have-enough-power/
yes plenty really a 650 would be plenty but a 750 is awesome
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/370936-do-i-have-enough-power/#findComment-5022070
The GTX 970 isn't really a power hungry card, I've got the g1 gaming and I can OC both it and my CPU on a 600W PSU and still have shitloads of headroom left.
You'd most likely even be fine with a higher quality 500w power supply.
https://linustechtips.com/topic/370936-do-i-have-enough-power/#findComment-5022090
600 would be enough in most cases even when overclocked.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/370936-do-i-have-enough-power/#findComment-5022092
enough and i think you mean the gtx 970 aCx 2.0
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/370936-do-i-have-enough-power/#findComment-5022095
I have an Asus Strix GTX 970, 750Watt is awesome, though I do recommend a good 80+ Gold as I've seen complaints about the 80+ Bronze's with the card.
Also dual GTX 970's can run on a 750Watt Power supply.  I had dual 970's but I gave one to a friend of mine.  No issue with my Max O/C running some demanding games.
https://linustechtips.com/topic/370936-do-i-have-enough-power/#findComment-5022116
i dont want to go offtopic, but "complaints about 80+ Bronze psu" ?
well thats interessting...
I guess thats a placebo. :P
https://linustechtips.com/topic/370936-do-i-have-enough-power/#findComment-5022128
Depends on the CPU you are using. OC'd X99 or FX-9590 you're going to be pushing it a bit, but still doable if you get good clean power delivery.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/370936-do-i-have-enough-power/#findComment-5022131
Well ffrom what you have said yes, 1 970 is gonna be a piss take for an 800 watter
CPU-i5 4690k 4.4ghz @ 1.190V, MOBO-MSI z97 gaming 3, Cooler-hyper 212 evo, GPU- r9 290x asus directcuII (-37Mv), Storage-120gb v300(switching soon), 1tb caviar blue, CASE-Red/black h440, PSU-Antec TPC 650.
https://linustechtips.com/topic/370936-do-i-have-enough-power/#findComment-5022189
