Overclocking a laptop? Help!
Solved by DevilishBooster,
Why are you trying to OC a laptop? You can't do anything to increase the cooling to handle the extra heat. I would strongly suggest against it.
PopsicleHustler ·
Posted in Audio0 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases7 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
play_circle_filled
Latest From ShortCircuit:
