Long story short, someone built his computer with a semi-decent gpu. He upgraded it and complained about problems. I took a look at it and he has a Power Man 450W PSU. The computer uses up about 338W according to PCPartPicker. Im pretty sure its the not-so-good PSU. I told him there are a few options. Either get a better PSU or downgrade the GPU to a less power consuming part. I need reccomendations for a PSU. Heres a link to his computer partlist. http://pcpartpicker.com/p/6CMrCJ
(PCPartPicker did not even have any Power Man brands of PSU)
Thanks
Case: NZXT S340 || CPU: i7 4790k || Cooler: Hyper 212 EVO || GPU: GTX 770 || Mobo: Z97 PC Mate || Storage: 240GB Sandisk Extreme Pro || RAM: 4x4GB 1333mHz
https://linustechtips.com/topic/370514-friend-having-power-issues/
Thanks
I would recommend changing that PSU, I've never heard hat brand before and it's probably not capable to delivering it's max rated wattage effectively especially if he overclocks.
