PoE problems with Camera
Go to solution Solved by TheOrdix,
It works! The 48V 1.25A PSU came yesterday and it works now. In conclusion: The Camera works with 12V if you plug it directly into the cam, but you need a 48V PSU for your PoE injector if you want to use that.
Thank you all for your help
Hello,
I need help with the setup for an IP camera. This is what i what i have at home:
Camera
HIKVISION DS-2CD2032-I 3MP
http://www.ebay.de/itm/HIKVISION-DS-2CD2032-I-3MP-HD-1080P-IR-PoE-UBERWACHUNGSKAMERA-NETZWERKKAMERA-4MM-/391054826984?pt=LH_DefaultDomain_77&hash=item5b0caf1de8
PoE injektor
Alfa 8ports passive PoE injektor
http://www.alfa.com.tw/products_show.php?pc=120&ps=162
Power supply
12V 1A
http://www.amazon.de/gp/product/B006NYKACA/ref=ox_sc_act_image_2?ie=UTF8&psc=1&smid=AVYP4TPWVFZRN
If i plug in the camera only with the power plug and a LAN cable it works perfectly. But if I use the injector (same power supply) it wont power on.
Am I missing something? I dont know what i´m doing wrong, please help me.
https://linustechtips.com/topic/369840-poe-problems-with-camera/
Hello,
Camera
PoE injektor
Power supply
12V 1A
Did you check your LAN cable? If you terminated it could be missing a link. Also check if you got the right sides.
https://linustechtips.com/topic/369840-poe-problems-with-camera/#findComment-5007714
I tested 3 different ones. I dont think that all of them are broken :D
Of course. And I guess you checked and plugged the cables in the right sides, happened to me quite a few times. By the ratings the Injector seems to support your voltage. Did you connect only one camera?
https://linustechtips.com/topic/369840-poe-problems-with-camera/#findComment-5007771
Yes, only the camera. i bought a big one because i want to add more in the future, if i can get the first one to work...
I connected the switch to the "LAN" side of the injector and the cam to the "PoE" side and tried both button orientations.
https://linustechtips.com/topic/369840-poe-problems-with-camera/#findComment-5007819
To add more devices you are going to need a higher voltage PSU. But the max is 48V meaning you can add only 3 more devices. Anyways back your issue, it could be that the injector is broken or that it distributes the 12V across all ports meaning you get ~1.5V per port. Does the power LED on the injector turn on?
The only way to check how much voltage you get is to measure it with a voltmeter(multimeter). If you have one, plug the RJ45 cable into the PoE injector and probe each contact on the other side until you get a reading.
https://linustechtips.com/topic/369840-poe-problems-with-camera/#findComment-5007892
I dont have a multimeter, but the Led turns on :D
https://linustechtips.com/topic/369840-poe-problems-with-camera/#findComment-5007924
or do I have to buy a 48V psu if i want to use poe? never used it before...
https://linustechtips.com/topic/369840-poe-problems-with-camera/#findComment-5007948
You are going to need a bigger PSU you could get a 48V one I guess. The thing is, when you plug it the 12V PSU into the injector and the other end into the camera you are essentially getting ~10V to your device, and this is likely the cause of the issue.
https://linustechtips.com/topic/369840-poe-problems-with-camera/#findComment-5008085
I've seen cheaper less well made injectors do more bad than good, I would look at it first if you are sure all connections are correct and everything else is setup properly.
System/Server Administrator - Networking - Storage - Virtualization - Scripting - Applications
https://linustechtips.com/topic/369840-poe-problems-with-camera/#findComment-5011427
Do you have any other PoE capable devices? You might want to return the injector and get something separate PoE injector for every device.
i grabbed a multimeter from a friend... i can measure the same voltages at the end of the lan cable and the power supply. A little less than 14V
https://linustechtips.com/topic/369840-poe-problems-with-camera/#findComment-5012094
https://linustechtips.com/topic/369840-poe-problems-with-camera/#findComment-5076280
