Hi all,
I have done some researching and have come up with the following parts for a budget ($650), light gaming (MIncraft) computer. Mainly I am using this computer for college however. Do you all have any suggestions on the build? Also, I know this is on the lower end of a PC so would it be better to just buy a pre-built computer than to try to build this one? I am from the US. I am planning on using a single monitor and I'll need peripherals as well as an OS but I did not include them in the budget. I need a new computer because the Chromebook is not cutting it by a long shot.
http://pcpartpicker.com/p/VsZMxr
Thank you all for your help!
https://linustechtips.com/topic/368751-final-build-check-up/
What else would the system be used for?
Is the optical drive really necessary?
https://linustechtips.com/topic/368751-final-build-check-up/#findComment-4992217
Generally, looks fine.
Guarantee there is going to be an Intel vs AMD debate, and my two cents is don't get a G3258, and get 4 threads somehow.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
https://linustechtips.com/topic/368751-final-build-check-up/#findComment-4992219
I will be using the system for school mainly. Like internet and excel spreadsheets so nothing heavy duty. I will be playing games occasionally like Minecraft. I don't think it is super necessary
https://linustechtips.com/topic/368751-final-build-check-up/#findComment-4992248
It would be better to state your entire budget and plan the system as a whole including the OS and peripherals if you're going to buy them anyway. Separating budget is just another way of limiting options.
https://linustechtips.com/topic/368751-final-build-check-up/#findComment-4992303
This is what I would do personally:
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($66.98 @ Newegg)
Video Card: EVGA GeForce GTX 750 Ti 2GB FTW ACX Video Card  ($129.99 @ Newegg)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  ($14.99 @ Micro Center)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($99.99 @ Newegg)
Monitor: Acer G227HQLbi 60Hz 21.5" Monitor  ($119.99 @ Amazon)
Total: $662.88
Generated by PCPartPicker 2015-05-17 22:49 EDT-0400
https://linustechtips.com/topic/368751-final-build-check-up/#findComment-4992335
Okay, my entire budget is $800. I am looking at the OS costing $100 and the peripherals close to $50. The rest of the system will be $650
https://linustechtips.com/topic/368751-final-build-check-up/#findComment-4992348
If your are focusing on school work and minecraft this is what I would chose: http://pcpartpicker.com/p/wRcwnQ
In minecraft with optifine installed and taking advantage of all 6 cores this thing will easy hit +120fps on far render distances.
You don't need a high end graphics card for minecraft (the R9 280), it is very very CPU intensive, but with a 2gb R7 260X you can still play new games like GTA V at 1080p with very high settings and hit 30fps.
I also threw in a windows license because you need that unless you want Linux or another operating system.
The power supply is very overkill but its reliable and cheap with a very good efficiency rating.
Upgrades you could do in the future would be.
-SSD
-Another 2gb R7 260X for crossfire
There is 20$ left for anything else such as.
-more fans
-bling
-more money in your pocket
https://linustechtips.com/topic/368751-final-build-check-up/#findComment-4992441
What kind of peripherals do you need?
https://linustechtips.com/topic/368751-final-build-check-up/#findComment-4992712
A keyboard and mouse. I have speakers already
How's this look instead? http://pcpartpicker.com/p/4XsDyc
https://linustechtips.com/topic/368751-final-build-check-up/#findComment-4993122
It looks pretty good. What is the benefit of getting a SSD?
The system becomes much more snappy and responsive compared to just using a hdd--it's a world of difference.
https://linustechtips.com/topic/368751-final-build-check-up/#findComment-5009938
