Hello! I have a Corsair H110 with Noctua Nf-A14's at full speed. I am folding right now (90% cpu usage) and my temps are low 80's is that normal? it doesn't seem like it to me. (i7 4790k @4.19 ghz). Thanks!
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
https://linustechtips.com/topic/368706-h110-temps/
With that much load on it yeah it's normal. Don't let it get above 90 though
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/368706-h110-temps/#findComment-4991603
huh, My stock cooler cooled it at 88c. well, at least it's real quiet!
https://linustechtips.com/topic/368706-h110-temps/#findComment-4991615
Lol I don't think it's possible for my APU ( sadly it's an old a6-3650 ) without blowing up lol
https://linustechtips.com/topic/368706-h110-temps/#findComment-4991627
Low 80s is not bad under full load. What is your ambient temp and idle?
Ambient temp- 30.5 c
idle temp- 34 c
https://linustechtips.com/topic/368706-h110-temps/#findComment-5000346
Those temps are relatively low, not saying that your load temp is too high, but there's probably a couple of things that you can try to lower it down a tad bit. Have you tried flipping the fans? or maybe change your case airflow set up and see what orientation is optimal for you system.
Also, those Noctua fans, are they static pressure fans?
https://linustechtips.com/topic/368706-h110-temps/#findComment-5000497
My current setup is in the H-440. I have the three stock nzxt 120mm fans in the front bringing air into the case, all down-volted with three of the Noctua adapters. I then have in the back, a stock 140mm nzxt fan down-volted with a Noctua adapter pushing air out. I then have two Noctua static pressure fans blowing air out through the radiator into my room. (i have them set as push rather than pull because it's quieter).
https://linustechtips.com/topic/368706-h110-temps/#findComment-5000740
