Problem wih my friend computer
Go to solution Solved by Kirjoittamaton,
Problem solved cooler was full of dust, but not working. motherboard is broken and my friend ordered new one
Hello my friend pc is not working,
specs:
AMD FX 8350
Corsair hydro series h55
Asus m5a99x
Kingston fury black 2x4gb
xfx 750w (dont know model)
ati radeon hd 6790
idle temp is around 60-70c
and when its cooled off temp is temporarily at 45-50c
i tried to change thermal paste with no effect.
When he plays cs go after couple of minutes pc shuts down and same is with borderands 2.
Bios is updated to newest version
https://linustechtips.com/topic/368538-problem-wih-my-friend-computer/
Sounds like it's overheating. Maybe RMA the CPU cooler?
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
"idle temp is around 60-70c"
i knew AMD ran a bit hotter than intel, but that seems on the high side...
what are his 100% load temps like? i feel like this is a thermal issue.
thats not actually that bad 85 is teh worry point
EDIT: Read it wrong :P
GPU: RTX 2080 Super        Keyboard: Corsair K70 MK.2 RGB
CPU: i7-9700K        MouseLogitech G PRO Wireless
RAM: 16 GB Corsair Vengance PRO                                                         Headset: Corsair HS70 PRO Wireless
PSU: CX650F        MousepadCorsair MM500 Extended 3XL
MOBO: Asus Prime Z390-A        ControllerDualSense 5
Case: Lian Li Lancool II        CameraCanon EOS M50
Monitor: Samsung Odyssey G5        CoolingCorsair H100i Platinum
The white Rabbit        MicrophoneTrust GXT 252+
What's wrong with your friend Computer?
jk, jk.
Sounds like a defective cooler, RMA?
Mobo: Gigabyte 970A-DS3P CPU: AMD FX 8350 RAM: Kingston HyperX Fury DDR3 8gb (2x4gb@1600Mhz) GPU: Gigabyte R9 280x (factory oc) PSU: Thermaltake SmartSE 730w Case: Corsair 200R
Blog thingy <----
jk, jk.
You beat me  :angry:
00110000 00110001 00110000 00110000 00110000 00110000 00110001 00110000 00100000 00110000 00110001 00110001 00110000 00110001 00110001 00110001 00110001 00100000 00110000 00110001 00110001 00110001 00110000 00110000 00110001 00110000 00100000 00110000 00110001 00110001 00110000 00110000 00110001 00110000 00110000 00100000 00110000 00110001 00110001 00110000 00110000 00110001 00110000 00110001 00100000 00110000 00110001 00110001 00110000 00110001 00110001 00110000 00110001
we maybe should try air cooler
No.
Is the water cooler plugged in?
Both fans, and the pump?
