Having serious headset issues.
Thanks for the reply I ended up seeing this other one after looking around more.
Do you think this USB splitter would work as well? I think it would be more convenient because there's only 1 wire and also I could keep the PC speakers plugged in for when I wanted to use them.
http://www.amazon.com/1-35mm-Female-Connector-Power-Cable/dp/B00A151Y9K?tag=hardfocom-20
No, that is for charging, it has a pin inside it. Are you using a desktop that has front mic/headset headers? If so get the headset splitter cable and plug your headset into the front, then plug speakers into the back of computer. You may have to mess with audio control to make them separate audio devices. If you do not have front inputs get the audio splitter cable for your headset, and then this http://www.amazon.com/Syba-SD-CM-UAUD-Adapter-C-Media-Chipset/dp/B001MSS6CS/ref=sr_1_1?ie=UTF8&qid=1431921398&sr=8-1&keywords=usb+audio+splitter to plug in your speakers to usb.
