Some years ago i've got a PC that lasted pretty much good for me for the couple of years, but with the new games and all it started to show its age (Especially the GPU)
I'm thinking to get a new GPU for it but not sure if its gonna bottleneck (Google says bottlenecking is bad)
My PC specs atm are:
CPU: Intel Pentium G630 @ 2.7Ghz
GPU: Nvidia Palit GT630 2 GB
RAM: 4 GB (Dunno which one)
PSU: XFX Pro 550W
Mobo: MSI H61M-P20 G3
The GPU i want to change to is GTX 750 Ti, to be more specific, this one. http://www.gigabyte.com/products/product-page.aspx?pid=5083#ov
So bottleneck, yes, no, maybe? Should i buy the card?
https://linustechtips.com/topic/368251-will-it-bottleneck/
Yeah you should not do anything to that...
Take the psu out and the hard drive and RAM and rebuild every other part.
https://linustechtips.com/topic/368251-will-it-bottleneck/#findComment-4984999
There will not be a bottleneck with that combo all do you will want to get at least 8gb of ram.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/368251-will-it-bottleneck/#findComment-4985000
