Tired a new cable too, think RMA is the only way now
I had a strange issue with my Gigabyte 970, if I had 2 DP cables connected then HDMI wouldn't work, same if I had 1 DP, 1 DVI and one HDMI. Not sure why, but try unplugging other stuff to see if that helps. Then RMA the card with a note of the fault in the box for the testing guy to see.
https://linustechtips.com/topic/367945-gtx-970-hdmi-help/#findComment-4981515
