I was going to buy a EVGA 600B 600W 80+ Bronze Certified ATX Power Supply, but i dont know if is overkill or just right for the next system
MOBO: Gigabyte LGA 1150 Intel B85 Motherboards
CPU: Intel Core i5-4570 Haswell Quad-Core 3.2GHz LGA 1150
COOL: Cooler Master Hyper 212 EVO - CPU Cooler with 120 mm PWM Fan
RAM: Crucial Ballistix Sport 8GB (1 X 8GB) DDR3 PC3-12800 1600MHz
CASE: Cooler Master N200 + 2x Cooler Master SickleFlow 120 - Sleeve Bearing 120mm Blue LED Silent Fan and 2 stock 120mm fans
Storage: Seagate Barracuda  1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
Storage: ADATA Premier SP600 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
GPU: Not decided yet, between R9 280, GTX 760, R9 285, R9 280x, GTX 960 and R9 290 (probably R9 280x)
I came from the video "https://www.youtube.com/results?search_query=power+supply+as+fast+as+possible"and i dont know if going for 600w is a good idea anymore
https://linustechtips.com/topic/367876-best-power-supply/
600 watts will do fine. I would go with the 280x, but try to get the 290 if you can.
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/367876-best-power-supply/#findComment-4980259
It's a decent PSU but there's others in the price range that are better, such as the Capstone 550W.
"Rawr XD"
https://linustechtips.com/topic/367876-best-power-supply/#findComment-4980270
600W is enough for your system :)
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/367876-best-power-supply/#findComment-4980294
How much will you be paying? There may be a better PSU on offer
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/367876-best-power-supply/#findComment-4984551
$50dlls
If you can spend a bit more then these are both better options and are honestly the minimum I would go. Since the 600B is already
http://pcpartpicker.com/part/xfx-power-supply-p1550sxxb9
http://pcpartpicker.com/part/seasonic-power-supply-s12ii520bronze
Unless you're going for GTX 960, in that case, even this is enough http://pcpartpicker.com/part/seasonic-power-supply-ss350etbronze
"Rawr XD"
https://linustechtips.com/topic/367876-best-power-supply/#findComment-4989015
isnt 350 below the need of the system alone without the GPU?, i ran a calculator and told me 410 without the GPU
https://linustechtips.com/topic/367876-best-power-supply/#findComment-4989462
Nope. GPU is rated for 120W, CPU for 85. That's 205W for the two most power hungry components, everything else will use at most 50-100W.
As stated, 350 will be fine with a GTX 960 system, but not with a competing AMD card. You'll want at least 500W for a 280/X and 550W for a 290.
"Rawr XD"
https://linustechtips.com/topic/367876-best-power-supply/#findComment-4989472
