Case Fan Help
By
Made In Canada
in Cooling
in Cooling
Solved by TheGeeker,
corsair do some great fans, check out the corsair sp120 series. they do quiet ones and performance ones.
If you go for the looks corsair fans are great. Just the expensive fans are not much better.
YoungBlade ·
Posted in CPUs, Motherboards, and Memory2 -
derekchan ·
Posted in New Builds and Planning6 -
5
2
5
kerriya ·
Posted in Cases and Mods9 -
octester ·
Posted in Troubleshooting8
play_circle_filled
Latest From ShortCircuit:
