Ok, so i made a thread the other day but it died, it was about my graphics card (Asus GTX 760) causing my computer not to start when it was in. Every one said it was the power supply but i had it tested and the guy said it was fine (but he didn't seem bothered by anything) so i tested it my self and the PCI-E connector was putting out 12.4v rather than just 12v is this the issue and has it fried the card? The computer in question is on, using the mobo for the monitor and the same PSU. so all other parts are ruled out (i think)
Specs:
PSU: Acbel 550w
CPU: AMD Phenom II X6 1035T
Graphics Card: Asus GTX 760
RAM: 8gb of i have no clue DDR2
Mobo: Am3+ got it from the dumb edition
https://linustechtips.com/topic/367591-possible-power-supply-issue/
The ATX specs state a tolerance of 5% on all voltage rails so that means 11.4V to 12.6V is within acceptable range.
Do you have a spare PSU? Find one that you know is working okay and try using that. Ask the repair guy if he has a good power supply you can use to test your system.
Btw, on the thread you linked, what particular part caught fire?
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
I don't have a spare PSU to test the system and the guy at the store wouldn't let my buy one and return it if it wasn't the issue.
Part of the card that caught fire: http://imgur.com/OWWsOfh PS. imgur flipped the image
Bring your system to the store and ask him if you could borrow a woking power supply and test if its the issue.
60FPS Microwave
easier said than done given it is in a 900D (i know not much of a system to be putting in a 900D but the opportunity came up to purchase one at a discount and i planed on getting one for a upgrade so)
