Processor & Graphics Card Help
I wasn't sure where to post this as it's about a processor and a graphics card but I'm having trouble choosing a processor and graphics card.
Heya,
It depends on what your intentions are. If you gaming and do light work on your computer. I would recommend a low end i5 Intel CPU i5 3470 or the AMD FX-6300. If you wish to overclock, go with the 3570k or or the AMD FX-8350.
If you do very heavy video editing or transcoding you want to get a multcore/hyperthreading CPU. either the 3770k (on the z77 platform) or the 4770k (on the z87 platform) or the FX-8350 from AMD.
With the GPU, any nVidia card from the 700 series (760, 770, 780) would do great. Again, it depends on the usage. for gaming, at least the 760 (preferably the 770 or 780) or the Radeon 7950.
Hope this helps ^_^ ,
Elven
