Hello there, ive been doing some research on some gpu water blocks and im in need of a little help because ive been told i might need to buy 2 different water blocks. i have an Nvidia 970 Gtx and i also have a MSI 970 Gaming gtx. Please help me which waterblock would be compatible for each. I've been looking at ekwb, swiftech, and stuff at amazon. thank you in advance!
https://linustechtips.com/topic/366914-gpu-waterblocks-help/
Use EKWB's cooling configurator it will be the best bet for blocks. the only issue I see is possibly the ports not lining up and you would have a strange tubing runs or have to do some funny adapting to connect the GPU's together.
http://www.coolingconfigurator.com/
https://linustechtips.com/topic/366914-gpu-waterblocks-help/#findComment-4969086
