diferent temps
Go to solution Solved by GamerDad,
If those readings are in fact accurate, your CPU is running fine. If it was reading at 170-180 degrees celsius I'd say it would be way too hot but in fahrenheit it's perfectly fine
If you're concerned about accuracy, stick a real thermometer in the case as see if your software corresponds with the thermometer. If they do, then you know you can rely on them. If there's a big difference, you might want to look for another software solution.
With that said, different software reports differently based on how the recordings are made and where they're coming from.
If the temperatures are accurate and you're still concerned, you might want to look into moving your PC into a cooler room and testing your cooler and fans to see if they might be malfunctioning.
I have diferent cpu termps in every monitor programs, I dont know in what to trust, help?
http://postimg.org/image/t5ddaj06b/
Ryzen 5 2600X / ASRock Fatal1ty B450 Gaming K4 / G.Skill RIPJAWS V 16GB (2X8) 3000Mhz CL15 / Gigabyte RTX 2060 Super Gaming 8GB OC / Corsair RM650X 2018 / Crucial BX500 240GB / Seagate Barracauda 2TB 7200RPM Cooler Master MasterBox E500L /  ASUS TUF Gaming VG27WQ // Rog Orion / Corsair Harpoon RGB Pro / Cooler Master MasterKeys Lite L / Xbox One Red Sport  Special Edition Controller for Windows
https://linustechtips.com/topic/36656-diferent-temps/
somebody?
https://linustechtips.com/topic/36656-diferent-temps/#findComment-471590
are this temps bad?
the cpu is on stock.,Maybe I might not applied thermal paste well
 My cooelr is true spirit 140
https://linustechtips.com/topic/36656-diferent-temps/#findComment-471981
https://linustechtips.com/topic/36656-diferent-temps/#findComment-472042
