Help a newcomer to software engineering.
Solved by Stefan1024,
- snip -
1) Here in europe all bachelor degrees are standardized and count equally. But I'm not sure about the situation in Mexico...
2) What kind of software do you want to develop?
- For embedded systems and micro controllers C or C++ is the best way to go.
- For drivers on windows / linux cou can also use C.
- For applications you need a OOP language like Java, C# (can't give you the best advise here since I'm programming embedded systems)
- For stuff like websites there is also HTML and so on....
