Hi there. Apologies if this is in the wrong section.
I built my first PC 5 years ago. I was quite the newbie back then. I'd still consider myself the same.
Anyway, I've hardly upgraded it since. I've only put in an SSD and a new HDD for storage.
Anyway, to the point. My CPU has been running quite hot at low load recently. I'm using the stock cooler as I didn't factor aftermarket coolers back then. I'm looking into improving the airflow in my case.
I've managed to get a Corsair H100i quite cheaply. I'm also looking into getting some new fans.
My question is, how should I set up the fans and H100i for the best airflow and cooling performance in my case?
Here are my specs:
Case: Coolermaster Cosmos S
Processor: Intel® Core i7 CPU 920 @ 2.67GHz
Motherboard: Asus Rampage II Extreme X58
Memory: 6 x Corsair Dominator 2GB DDR3 RAM
GPU: Gainward GTX260 Golden Sample
PSU: Corsair 850w CMPSU 850 HXUK
SSD: Samsung 256GB 850 Evo
HDD: 3TB WD Green
1.5TB Samsung HD154 UI
OS: Windows 7 64bit Home Premium
Thanks guys!!!
https://linustechtips.com/topic/366346-cooling-pc-newbie-build/
Exaust for least dust (I only recommend if you already have good case airflow / static pressure)
Intake for fastest cool down after switching from load to idle imo
Also I recommend two of these fans for great quiet performance :D
https://linustechtips.com/topic/366346-cooling-pc-newbie-build/#findComment-4962089
Not to sound like an ass, but whenever I see the poo brown of Noctua, I puke a bit in my mouth everytime :D
Same :/
https://linustechtips.com/topic/366346-cooling-pc-newbie-build/#findComment-4962433
I would switch the top H100i to OUT also, heat in the case rises, so would be better
For the fans, the Noctuas are good, or Akasa Vipers - they have very good airflow when placed against a radiator, because they have high static pressure, which is good :)
https://linustechtips.com/topic/366346-cooling-pc-newbie-build/#findComment-4962568
