Hey guys, I'm going to make a custom case for my summer build and I want to know if this airflow situation would be okay. I wouldn't have any HDD cages in the case so the entire front end of the case would be shifted forward in order to make the airflow a little bit better. The front end and the fans would essentially be right next to the gromets for cabeling. Anyways, there are two chambers, main and power supply plus cables much like the H440, so I would be using these fans for intake and exhaust: NF-P14r redux-1500 PWM. The main question I have, is can the Dark Rock 3 from Be Quiet! handle passive cooling from these three fans? The cooler would be mounted horizontaly for improved asthetics.
-Evan
https://linustechtips.com/topic/366253-custom-case-airflow/
A properly proportioned diagram would be useful.
https://linustechtips.com/topic/366253-custom-case-airflow/#findComment-4961049
