What's the system being used for?
Why 2 ssds and such a large case? No mass storage?
https://linustechtips.com/topic/366235-first-personal-build/#findComment-4960774
PCPartPicker part list: http://ca.pcpartpicker.com/p/wZq8kL
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($466.90 @ DirectCanada)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($34.98 @ NCIX)
Motherboard: MSI X99S SLI Plus ATX LGA2011-3 Motherboard  ($236.49 @ Newegg Canada)
Memory: Crucial 16GB (4 x 4GB) DDR4-2133 Memory  ($184.75 @ Vuugo)
Storage: Silicon Power S60 120GB 2.5" Solid State Drive  ($59.16 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($84.99 @ Newegg Canada)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE 3X Video Card  ($639.99 @ NCIX)
Case: Corsair 200R ATX Mid Tower Case  ($59.99 @ Canada Computers)
Power Supply: Corsair CSM 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($69.99 @ NCIX)
Total: $1837.24
Generated by PCPartPicker 2015-05-14 00:07 EDT-0400
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
https://linustechtips.com/topic/366235-first-personal-build/#findComment-4960794
As woodenmaker said, what is this gonna be used for?
First, what are you using the PC for? Gaming? Streaming? Editing? Rendering? Home?
Because it depends what you're doing with your computer
ok so the main use of the pc will be gaming. but the second use will be a bit of Cad not too crazy with it just some basic stuff.
and the mass storage will be on my NAS so the two SSDs will be in Raid 0 for better speed and backed up every few days.
-Trizmo
https://linustechtips.com/topic/366235-first-personal-build/#findComment-4960819
-Trizmo
K, then change GPU to 290x and get a higher q psu
Lets all ripperoni in pepperoni
https://linustechtips.com/topic/366235-first-personal-build/#findComment-4960821
You can't just randomly post "300th post!".
Post something relevant or its spam
-Trizmo
1. Sorry.
2. I would get a hdd just to have one. you never know when you will need it.
https://linustechtips.com/topic/366235-first-personal-build/#findComment-4960854
-Trizmo
Why would the speed from raid 0 be necessary?
https://linustechtips.com/topic/366235-first-personal-build/#findComment-4960860
I think theres no monitor in this build ... you know, the most important part.
A working gsync/freesync loop build will be about 900x better enjoyment than anything else.
yah i just recently bought 2 24" acer monitors for my desk.
because why not. im spending this much might aswell make read write speeds insane aswell. :P
-Trizmo
https://linustechtips.com/topic/366235-first-personal-build/#findComment-4962822
biggest difference i would see between those parts is about $700 and i chose the case because i like the look
-Trizmo
If your main use for the pc is gaming, with a bit of CAD work then I would go with an i7 4790K build.
Something along these lines. The psu will handle a 2nd GTX 970.
I went with a different case, but everything will also fit in the CM Stryker.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($410.98 @ Newegg Canada)
CPU Cooler: Phanteks PH-TC14PE_BK 78.1 CFM CPU Cooler  ($111.98 @ Amazon Canada)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($154.98 @ Newegg Canada)
Storage: Crucial BX100 500GB 2.5" Solid State Drive  ($229.99 @ NCIX)
Case: Phanteks Enthoo Luxe ATX Full Tower Case  ($189.99 @ NCIX)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($133.58 @ DirectCanada)
Total: $1756.15
Generated by PCPartPicker 2015-05-14 09:50 EDT-0400
https://linustechtips.com/topic/366235-first-personal-build/#findComment-4962927
RAid 0 only increases sequential transfer speeds though which isn't really useful unless you're frequently moving large files.
https://linustechtips.com/topic/366235-first-personal-build/#findComment-4966328
