Changing motherboard with same model
Solved by mgsstar,
If you haven't changed any bios settings, it would be fine. But your RAID 1 configuration may not work. In RAID 1, if one of the drive fails, you can access it on the second drive. So you could just recreate the array. But backup your data before doing this to avoid the loss of data.
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases7 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning21
play_circle_filled
Latest From ShortCircuit:
