Hi, im looking to make a gaming Pc my processor is a Xeon E3 1240 V2 and GPU is an R9 280x. i found this motherboard intel dq67sw and im wondering if this will work for me. it has sata 6gb. i have a xeon so no overclocking. but it has a pcie 2.0 slot while my processor supports 3.0 and max ram frequency of 1333. this costs about 45$ while the P8b75M costs 85$. so what do you recon? my primary focus is gaming and Coding as i am a computer science student on a budget :/
https://linustechtips.com/topic/365966-motherboard-help/
Neither of those boards are the right socket.
You need a socket 1150 board..
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/365966-motherboard-help/#findComment-4957028
@FruitBasketSilex
Nah they're both lga1155 chipsets, just one is a Sandy the other is a newer Ivy.
The E3 1240 V2 is an LGA1155.
@Stumar
Either will work but the P8B75 has more features and more likely to support your CPU out of the box. I'd go for the P8B75 personally.
PCI-E 2 vs 3 is no issue, its backwards and forwards compatible and bandwidth isn't an issue. Yet. Give it a year or two in GPU tech.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/365966-motherboard-help/#findComment-4957086
@FruitBasketSilex
@Stumar
Huh, indeed you're right. Could've sworn the 1240v2 was an 1150.
I'd go with your recommendation then.
https://linustechtips.com/topic/365966-motherboard-help/#findComment-4957103
Don't worry, you're not crazy. There is an E3 1240 V3 that is LGA 1150 lol. Just to mess with your head.
https://linustechtips.com/topic/365966-motherboard-help/#findComment-4957189
Oh, yep. That's what I was thinking of.
https://linustechtips.com/topic/365966-motherboard-help/#findComment-4957193
