My first pc gaming build
Go to solution Solved by Man1ac123,
@brokencross
@SkywardKkalox
@grayblizzard
Thank you so much guys for your replys!
Based on what you guys said i came up with this:
CPU: Intel Core i3-4130 3.4GHz Dual-Core Processor  (€118.99 @ Amazon Deutschland)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  (€50.02 @ Amazon Deutschland)
Memory: Kingston Fury Series 8GB (1 x 8GB) DDR3-1600 Memory  (€61.89 @ Amazon Deutschland)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€58.49 @ Amazon Deutschland)
Video Card: Gigabyte GeForce GTX 960 2GB Video Card  (€208.99 @ Amazon Deutschland)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  (€47.87 @ Amazon Deutschland)
Total: €546.25
Generated by PCPartPicker 2015-05-13 22:49 CEST+0200
Please let me know if you find any problem or want to improve.
Hello guys,
So Ive been playing almost every game in my consoles (ps2, ps3) and now ps4 is out and i was looking about gaming pc. I heard is benefits and I was interested.
BUT i'm such a noob in this subject (reason i'm doing this). I made some research on the last month like builds, what blabla means and all the stuff that i found.
So basically i wanted to buy a ps4 first to play a game that is coming out in september but paying 400€+60€(game)(eventually a 50€ online sub.) was a bit pointless.
I already picked some parts but I don't know if they will do my purpose: http://pcpartpicker.com/p/LZMdWZ
already have optical drive and os.
The idea is to make a system that can run "Metal Gear Solid V: The Phantom Pain" on 1080p and 60FPS (because that's what the ps4 will run from what they said). (game : http://www.game-debate.com/games/index.php?g_id=7313&game=Metal%20Gear%20Solid%20V:%20The%20Phantom%20Pain )
But i want to have some upgrade possibilities. I really like the idea of having a 4K "1337FPS"(I don't know what a computer is capable of right now) in the future.
(Template below)
1. Budget & Location
Well i live in Portugal, not all components are avaible in local stores but there are some alternatives so it's not a big problem
My budget is 600€ max. But feel free to leave suggestions if you think I should spend a little more.
2. Aim
Like i said before the main purpose is to play MGS but i recently installed CS:GO.
3. Monitors
I don't want to spend more money now i have a monitor that I think it can run 1080p
4. Peripherals
Don't need
Thank you for reading guys, if you have any questions, ANY please ask.
https://linustechtips.com/topic/365819-my-first-pc-gaming-build/
Hello guys,
(Template below)
2. Aim
3. Monitors
4. Peripherals
Don't need
I am not an expert but this build will let you play games 1080p no Problem and is upgrade able but understand that the mobo and cpu do not over clock so I you wanted to overclock you would have to buy a new mobo and cpu later but really no need also this build is a little overpriced but is the best you can have I might be very wrong with the currency tho
http://de.pcpartpicker.com/p/BvBdWZ
There is the build
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/365819-my-first-pc-gaming-build/#findComment-4955217
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  (€50.53 @ Amazon Deutschland)
Case: Cooler Master Force 500 ATX Mid Tower Case  (€39.63 @ Amazon Deutschland)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  (€47.10 @ Amazon Deutschland)
Total: €585.62
Generated by PCPartPicker 2015-05-13 17:09 CEST+0200
This will be better seeing as MGS5 is going to be Nvidia optimised.
https://linustechtips.com/topic/365819-my-first-pc-gaming-build/#findComment-4955258
@Man1ac123
Faças o que fizeres não compres a 750Ti, é uma piada de gráfica.
@grayblizzard's build is pretty good, I'd suggest the same.
Caso queiras comprar uma fonte da EVGA, a Alientech tem.
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
https://linustechtips.com/topic/365819-my-first-pc-gaming-build/#findComment-4955260
@brokencross
Eu tinha visto este video https://www.youtube.com/watch?v=JxUPJdcChzE que mostrava o que 750 ti podia fazer e pareceu me bem mas se tu o dizes
Sim, a 750Ti é suficiente para teres uma performance equiparável à PS4, mas pelo mesmo preço consegues arranjar muito melhor. Nomeadamente, AMD.
Uma R9 270, por exemplo, é superior à 750Ti e custa virtualmente o mesmo.
https://linustechtips.com/topic/365819-my-first-pc-gaming-build/#findComment-4956197
@brokencross
@SkywardKkalox
@grayblizzard
Total: €546.25
https://linustechtips.com/topic/365819-my-first-pc-gaming-build/#findComment-4956515
@brokencross
@SkywardKkalox
@grayblizzard
http://de.pcpartpicker.com/p/WHGMxr
looks like an awesome build will blow away a ps4 and also can do other stuff go for gold
https://linustechtips.com/topic/365819-my-first-pc-gaming-build/#findComment-4956542
@brokencross
@SkywardKkalox
@grayblizzard
(and i found out how to do the list )
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  (€68.12 @ Home of Hardware DE)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€58.59 @ Amazon Deutschland)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  (€47.29 @ Amazon Deutschland)
Total: €552.00
Generated by PCPartPicker 2015-05-13 20:27 CEST+0200
I would still suggest you go for 1 8gb stick of ram, as this motherboard only has 2 ram slots so it leaves you a free slot for dual channel later.
Single stick vs dual channel RAM don't affect gaming performance all that much. It's kinda invisible to the naked eye.
https://linustechtips.com/topic/365819-my-first-pc-gaming-build/#findComment-4957112
