What would you Guys say, if I threw the keywords, Cheap, Silent, Small + Black? (NO OVERCLOCKING)
Which / how many good combinations could be made?
Would be nice to have the components under 80'C
The aim is basically to have a console replacement.
So every suggestion, and ideas, from CPU, to controllers/Keyboards etc goes.
- I'm trying to avoid a keyboard / Mouse though.
Casual games will be played on steam, such as GTA V, Dark Souls, Dragon Age (All), Grid 2
It will be standing in the living room, beside the TV, so nothing too shinny with LED fans or anything.
That's annoying when you're trying to Watch a horror movie. :-P
Write Down some combinations, add Pictures, Parts list etc.
Currently I use the Logitech Rumblepad 2 controller, it is however wired, and also isn't supported automatically in too many games.
AMD Ryzen R9 5900X  | Arctic Liquid Freezer II 360  |  GIGABYTE X570S AERO G  |  2x32GB G'skill TridentZ 4000MHz  | MSI RX 6900 XT Gaming Z Trio 16GB Dark Base Pro 900 (Orange)  | TOSHIBA 4TB 3.5" Drive - Game Drive | KINGSTON SNVS1000G 1TB M.2 NVME SSD - Boot Drive | FSP Hydro PTM PRO 1000W |
Living Room PC: AMD Ryzen 2400G | MSI RX VEGA 56 8GB AERO | 2x8 GB Crucial Ballistix 2400MHz | Intenso 250GB SSD | Seagate 500 GB HDD | Node 202 + 850W PSU |
https://linustechtips.com/topic/365810-cheap-silent-small/
-snip-
would help if you told us your budget.....
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/365810-cheap-silent-small/#findComment-4955106
The most difficult part imo is choosing the right case. How small exactly do you want it to be? Should there be room for expansion? Or are you okay with an ITX system?
And also: what's your budget?
I'm okay with ITX. as long as the parts can be replaced. I can always get the ASUS mini 760 GTX for example :-D
https://linustechtips.com/topic/365810-cheap-silent-small/#findComment-4961595
You have to pick a solid case first for this kind of thing.
Can look around Cooler Master / Silverstone / Corsair for a solid mini itx case.
The rest of it depends on your budget.
I have no budget in mind, please try not to think about the Money, and try to be creative. Try to keep it logical, and Down to earth. Not wasting the Money for no logical reason or aesthetics only. :-P TV and TV-Table is Black, so a Black case is favorable.
https://linustechtips.com/topic/365810-cheap-silent-small/#findComment-4961603
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor  ($215.99 @ NCIX US)
CPU Cooler: Noctua NH-L9x65 33.8 CFM CPU Cooler  ($55.99 @ Amazon)
Motherboard: Gigabyte GA-H97M-HD3 Micro ATX LGA1150 Motherboard  ($69.99 @ SuperBiiz)
Storage: Crucial BX100 120GB 2.5" Solid State Drive  ($60.99 @ SuperBiiz)
Case: Corsair 350D MicroATX Mid Tower Case  ($79.99 @ Newegg)
Total: $951.41
Generated by PCPartPicker 2015-05-16 08:44 EDT-0400
Old Rig
https://linustechtips.com/topic/365810-cheap-silent-small/#findComment-4977659
