I am having problem starting up my pc I am getting MB led code 04 on the screen windows loading but stay that way. Any help would be appreciated.
CPU: Core I7 4790k @4.7Ghz MB: Gigabyte GA-Z97X-Gaming 7 GPU:GTX 980 Ti SLI RAM: Corsair vengeance pro 16GB 2400Mhz Storage: Samsung 850 PRO 512 GB boot drive, WD black 2TB PSU: Corsair HX1000I Display: Samsung UD590D 4K monitor Cooling: Corsair H100I GTX Keyboard: Corsair K70 RGB Mouse: Mionix Naos 7000 Operating System: Windows 8.1
https://linustechtips.com/topic/365806-first-build-issue/
This is my specs i7 4790k vengeance 2133 mhz ram evga GTX 980 superclocked corsair hx1000i powersupplie.
https://linustechtips.com/topic/365806-first-build-issue/#findComment-4954932
Is your CPU 12V 4/8Pin Power Cable Pluged in?
Yes sir.
https://linustechtips.com/topic/365806-first-build-issue/#findComment-4954935
is it a clean install of windows?
and specs please
Yes.
https://linustechtips.com/topic/365806-first-build-issue/#findComment-4954938
Gigabyte z97x gaming 7
https://linustechtips.com/topic/365806-first-build-issue/#findComment-4954954
So it freezes when it its booting?
SSD in AHCI?
Try unplugging USB devices.
Try different SATA cables.
Can it boot from Windows install disc?
Overclocked?
Quote if you want me to respond.
Sorry I am kind of noob in this I am not sure what AHCI but I am using corsair force ssd I am using external LG dvd player as optical drive and I am overlooking yet because I am using stock Intel cpu cooler.
https://linustechtips.com/topic/365806-first-build-issue/#findComment-4955011
Sorry I am not overclocking yet.
https://linustechtips.com/topic/365806-first-build-issue/#findComment-4955016
Make sure you install Windows when your drive is in AHCI. Make sure you are in AHCI by going into your BIOS and under whatever menu contains the storage settings make sure you are in AHCI not IDE.
I check my motherboard setting it's checked on AHCI mode.
https://linustechtips.com/topic/365806-first-build-issue/#findComment-4956198
