Posted May 13, 2015 hey guys ive been experiencing some weird shit with my new pc.the other day i was playing dota2 and my keyboard starting cutting out, then it wouldnt work at all, LEDS kept fading on and off and eventually i couldnt type at all. soon after it quit i then experienced a massive crash. i turned off the pc, made sure all my cables were seated correctly, powered back on again, went to login screen. i tried typing in my password, it maxed out characters in text field then pc shut off again. i waited awhile turned pc back on with no problem, logged in, ran antivirus scans, everything seemed to be fine. after this i played for almost two days with no problem then today while playing i ran into keyboard problem again. i tried dif keyboard and it didnt work either, my mouse works but no keyboard, and no crash this time. i dont think peripherals are the problem here, ive noticed a faint buzzing sort of noise and im 95% sure its my psu. i have a modular corsair CX600M psu. its 600 watts. this psu is supposed to be silent. do you guys think my PSU is the problem here? -i5 4690k cpu-GTX 960 gpu-8GB 1866mhz vengeance ram-Gigabyte mATX z97mx mobo -256gig SSD im not overclocking or anything, just playing dota2. Ive only had this pc built for about a week. ive had hours of gameplay with no problem but ive ran into this keyboard problem twice now, first occurrence a massive crash was included. what do you guys think ? Link to comment https://linustechtips.com/topic/365572-help-strange-problem-psu/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 13, 2015 Have you try updating your keyboard drivers and change what port you keyboard is plugged into Magical Pineapples
