Hi guys, I have had issues with the graphics on my pc (specs in sig) where things around the desktop where stuttering and jumping etc... and audio was also breaking up. After trying everything imaganable, I thought it must be one of my 660ti's but the problems goes when I only use the bottom 8X slot for either card (so both cards are good) and both bring the issue back when installed in the top 16x slot.
I have thoroughly cleaned the slot without any luck and I have also tried the standard things, such as clearing CMOS etc...
I really am stuck and some guidance from here would be greatly appreciated!
Thanks!
*this error shows up every time I get a stutter or jump that seems to be brought on by making the GPU work at all, such as when I open a new window with an animation or video playback etc...*
post-185202-0-09473800-1431459158_thumb.
- i7 3770k @4.5 GHz - ASUS P8Z77 - H80i - 16 GB Memory - EVGA 1070 FTW - corsair HX 750w psu -
https://linustechtips.com/topic/365370-pcie-slot-problems/
Was one of those standard things using the Nvidia driver un-installer and then reinstalling the drivers?
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/365370-pcie-slot-problems/#findComment-4949332
Have you tried re-installing the drivers?
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/365370-pcie-slot-problems/#findComment-4949338
That and even windows its self :(
https://linustechtips.com/topic/365370-pcie-slot-problems/#findComment-4949355
Sounds like you have to RMA the board to me.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/365370-pcie-slot-problems/#findComment-4949375
What's the Bios version?
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/365370-pcie-slot-problems/#findComment-4949377
I hate to say I think you may be right - would my board still be under warranty with asus? I brought it in May 2013...
https://linustechtips.com/topic/365370-pcie-slot-problems/#findComment-4949390
You'd have to check with them. It depends on the model and everything.
CPU-Z Verification
Laptop:
 Phone:
 Game Consoles:
https://linustechtips.com/topic/365370-pcie-slot-problems/#findComment-4949403
You'd need to check with Asus to see if it is. If not then its an example of something made to break after the warranty is expired.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/365370-pcie-slot-problems/#findComment-4949410
Okay, I'll do that - thanks
I hate having to rebuild my rig!
I know the feeling.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/365370-pcie-slot-problems/#findComment-4949453
Thanks for your help guys - I will email them and see what they say :D
You could try registering your motherboard with them first-I did that when my H87M-Pro was being a POS.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/365370-pcie-slot-problems/#findComment-4949506
hmmm.. what do you mean by registering with them?
https://linustechtips.com/topic/365370-pcie-slot-problems/#findComment-4949570
