Hi everyone, i´m planing on building my very first gaming PC, up until now i´ve played all my games on an old laptop and i finally decided to build a PC  i was hoping you guys could help me with some tips, since its going to be my first rig so i don´t know much about the hardware ill have to buy, i hope you guys can share a bit of your experience with me and help me out with this project.    :D
1. Budget & Location
i live in the US i´m planning on spending $1500 on just the components for the tower i have a separate budget for the case and peripherals.
2. Aim
i want to use the PC mostly for graphic intensive gaming
3. Monitors
i think i´ll only be using one
https://linustechtips.com/topic/365330-need-help-on-a-new-pc/
2. Aim
3. Monitors
What case is it? Just so we can work out compatible coolers.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/365330-need-help-on-a-new-pc/#findComment-4948647
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($26.98 @ OutletPC)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($112.99 @ SuperBiiz)
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1866 Memory  ($58.89 @ SuperBiiz)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($108.99 @ SuperBiiz)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.49 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card (2-Way SLI)  ($349.99 @ Directron)
Monitor: Acer H236HLbid 60Hz 23.0" Monitor  ($137.99 @ Best Buy)
Total: $1428.30
Generated by PCPartPicker 2015-05-12 14:01 EDT-0400
If it can fit in your case go for it.
https://linustechtips.com/topic/365330-need-help-on-a-new-pc/#findComment-4948661
Get @SkywardKkalox build. ^^
https://linustechtips.com/topic/365330-need-help-on-a-new-pc/#findComment-4948671
i live in the US i´m planning on spending $1500 on just the components for the tower i have a separate budget for the case and peripherals.2. Aim
i want to use the PC mostly for graphic intensive gaming3. Monitors
here PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($279.99 @ Micro Center)
CPU Cooler: Corsair H75 54.0 CFM Liquid CPU Cooler ($62.99 @ Newegg)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard ($135.49 @ Newegg)
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory ($113.49 @ Amazon)
Storage: Sandisk Ultra Plus 128GB 2.5" Solid State Drive ($76.99 @ Amazon)
Video Card: Asus GeForce GTX 980 4GB STRIX Video Card ($538.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($99.99 @ Newegg)
Total: $1360.42
Generated by PCPartPicker 2015-05-12 14:04 EDT-0400
https://linustechtips.com/topic/365330-need-help-on-a-new-pc/#findComment-4948694
Kills in gaming
Kills in multitasking
Kills in general
-edit That ram may hit the cooler, I'm not sure though
Storage: Samsung 850 Pro Series 256GB 2.5" Solid State Drive ($157.78 @ OutletPC)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive ($119.70 @ Newegg)
Video Card: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 Video Card ($544.99 @ SuperBiiz)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($102.99 @ Newegg)
Total: $1481.41
Generated by PCPartPicker 2015-05-12 14:13 EDT-0400
Things in build state: Lan room , Gaming PC
Things finished: Lol wut
https://linustechtips.com/topic/365330-need-help-on-a-new-pc/#findComment-4948705
Total: $1360.42
Trading hdd and ssd reliablity for liquid cooling. tsk tsk tsk
https://linustechtips.com/topic/365330-need-help-on-a-new-pc/#findComment-4948775
http://pcpartpicker.com/p/RkFyBm
Heres a lightyears better build compared to everything else that has been suggested here.
1300$ and has a working freesync loop on a 21:9 IPS, 75hz monitor. (i suggest you research what gsync or freesync is if you dont know already)
The result will be 900 times more enjoyable gaming than on any of the other SLI systems with a crappy, small TN screen - that have been suggested. Seems some people want to show off how sick system they are able THINK UP, instead of actually caring for the gaming experience.
https://linustechtips.com/topic/365330-need-help-on-a-new-pc/#findComment-4948923
I saw you on another build dissing people's builds frankly it's not in the spirt of building
-edit also that monitor has no reviews and could be a piece of shit
-edit people need mass storage and a-data is not well known
https://linustechtips.com/topic/365330-need-help-on-a-new-pc/#findComment-4949161
If you choose politeness over the correct/best answer... then GOOD LUCK! You deserve to make your own mistakes.
- go research what freesync is
- additional 40$ TB hdd is out of the question i guess
https://linustechtips.com/topic/365330-need-help-on-a-new-pc/#findComment-4950212
That monitor is magnificent, and A-data is well known.
Do your research before you post.
https://linustechtips.com/topic/365330-need-help-on-a-new-pc/#findComment-4961349
Kills in gaming
Kills in general
Total: $1481.41
Such a waste of money.
https://linustechtips.com/topic/365330-need-help-on-a-new-pc/#findComment-4961350
